Bavarian Soundwerks
Results 1 to 2 of 2
Thread: What Head Unit to keep from blowing up HK amp?
    Columbus, OH
    1998 M3/4/5
    Just got a 1998 M3 sedan with the 10-speaker HK system. In researching new head units the issue seems to be not trying to blow up the existing HK amp. Most of the head units have built-in amps. Iíve searched in here and people are using Alpines with the HK amp. Iím looking at the Alpine CDE-172BT (about $130 from Crutchfield) and it has 18 watts with 4 channels.
    Iím not ready to rewire the car to install an aftermarket amp. Will this Alpine work?
    Thanks.
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    I believe the inputs to the factory HK amp are balanced differential signals. These signalsí voltage levels are higher than line level (aka RCA) signals. That said, you best option is to find converters that transform the outputs from a head unit (whether they be line level or speaker level) to balanced differential signals. Also, check the audio section of other BMW forums. Lastly, try http://www.diymobileaudio.com.
  1. Alpine 9885 head unit or keep the stock head unit???
    By beshannon in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 11-08-2007, 03:27 PM
  2. Any way to add head unit and keep on board computer?
    By jcdavis in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 10-06-2006, 06:34 PM
  3. New head unit how to keep stock speakers?
    By jimeckles in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 05-30-2006, 03:59 PM
  4. 95 M3, need recommendation for CD head unit--and should I keep Nokia speakers?
    By hukalaki in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 06-02-2003, 09:28 PM
  5. replacing head unit while keeping factory amp?
    By vvtivanos in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 06-23-2001, 10:55 AM
