Results 1 to 4 of 4
Thread: Boost issues
    Jun 2018
    North carolina
    335i
    Boost issues
    Stock n54 not building over 5psi. Tried 2 different boost guage to make sure the first wasn't a faulty guage. Can't hear any audible leaks but haven't done a leak test. Any ideas on this?
    Feb 2009
    Arizona
    1998 e36
    5psi is base boost. It won't go past 5 psi if it detects any knock. Max stock boost is only 8psi
    Jun 2018
    North carolina
    335i
    Ok thanks. I knew the max was 8psi, but did not know about the base 5psi.
    Nov 2008
    Indiana
    97' 328is, 07' Titan
    .... if it's only hitting waste gate pressure then you either have a leak or a bad electronic boost control valve.
    1997 328is - Megasquirt PNP, Holset HX35, Deka 80lb injectors, SPA T3, Precision PW39 WG, Synapse Synchronic BOV, DKM Organic Twin Disc Clutch, Innovate LC-2 W/B, Mishimoto Intercooler, Mishimoto Catch Can, Mishimoto Rad, Devils Own Meth, Porsche 911 calipers with E46 M3 rotors, Corsa Exhaust
  1. Active C30 SC boost issue or not (only 6psi)
    By skyers28 in forum Forced Induction
    Last Post: 07-15-2008, 02:29 PM
  2. More CIS Boost Issues To Tune (Josh, please HELP!!!)
    By uberpanzer in forum 1975 - 1983 (E21)
    Last Post: 06-18-2008, 12:20 PM
  3. boost issues
    By fryguym3 in forum Forced Induction
    Last Post: 06-05-2007, 11:56 PM
  4. Replies: 20
    Last Post: 10-11-2006, 03:01 PM
  5. Boosting issues
    By ///M3Turbo in forum Forced Induction
    Last Post: 09-25-2006, 04:18 PM
