Results 1 to 3 of 3
Thread: E23 oil on plugs
    May 2018
    Syracuse
    na
    E23 oil on plugs
    Looking at my first e23. It’s in reall great condition but the owner mentioned oil on the plugs. Slight amount, and cleaning them off after 250-300 miles and it’s fine. He said it’s the Valve Guides but I’ve also read that piston rings can cause this. There’s no smoke or spuddering until after driving for the 250-300 miles.
    My question is, how to be sure if it’s the valve guide without taking the engine apart and what’s that entail as a repair? Taking the head off and to a machine shop? Any insight is appreciated, thank you.
    Mar 2013
    USA
    E21/early e23/e34
    It'll be much more helpful if you give a little more information about the car, namely how many miles the car has.
    Fouled plugs could be a rich condition also and when they foul they could look like oil, sort of.
    If the car has bad valve guides the car would almost certainly put out some smoke, usually at start up or under hard acceleration.
    Helpful also to know the color of the smoke, white or dark.
    If it is the guides then the head will have to come off, a diy if you're mechanical, otherwise a technician.
    Oct 2007
    Valley Village, CA
    1985 745i
    An easy way to confirm valve guides:
    Go downhill, decelerating in gear for a little while. When you get on the gas there will be blue smoke out of the tailpipe.
    Another sign is Park it after driving it, then start it about 30min later. You’ll see blue smoke out of the tailpipe upon startup.
    Rings will usually smoke on acceleration and higher rpm. Oil smoke is typically blue-ish in color.
    You can smell the exhaust and have an idea of what it is burning as well. However, fouled plugs after 2-300miles, you should be seeing a relative smoke show.
    Valve guide seals are not an easy DIY job. The entire head needs to be disassembled.
    Keep us posted!
    When your enemy is making a mistake, do not interrupt him.
  1. Oil on plug 1
    By Proctor750 in forum Forced Induction
    Last Post: 12-17-2010, 11:29 AM
  2. oil on plug M42
    By dlight26 in forum 1991 - 1999 (E36)
    Last Post: 11-20-2008, 04:23 PM
  3. oil on plugs? sell?
    By BMWMonarchE36 in forum 1983 - 1991 (E30)
    Last Post: 05-20-2008, 06:32 PM
  4. oil on plugs
    By red325bimmer in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 02-20-2008, 09:19 PM
  5. 1998 540i oil on plugs on driver's side only
    By sam1680 in forum 1996 - 2003 (E39)
    Last Post: 12-19-2006, 01:36 AM
