Hi all...
I have an 01 e46 325it sport manual. I have a sunroof problem (surprise, surprise). Had the typical sunshade issue, so I did the DIY...now I have trouble with the sunroof leaking. Leaks at the passenger front corner, down the A pillar.
Two of Boston's best indie BWM specialists have tried to fix it.
A. Shop in Boston fixed it...until I opened and closed the sunroof, then it started leaking again.
B. Shop just north of Boston found the drains were clogged. Blew them out and when they tested it at the shop, no leaks. On the way home, I open/close the sunroof, boom, it starts leaking again. Take it back, they cannot recreate the problem.
Shop #2 suggested taking it to ?Sunroof Doctors? in NH. Said they used to fix all the sunroof issues for Tulley. It's a franchise, and not crazy about having to drive 90 minutes one way to get it fixed. But I need the sucker fixed as I want to sell the car. If there is an indie that you know of that is a rockstar at fixing BMW sunroofs, I would appreciate it. I don't have the time to fiddle with it myself.
Sidenote: My driveway is on a slight downward slant, towards the passenger side. However, the sunroof worked previously, so I don't think my driveway is the culprit here.
Burgundy
PS. Community FYI: Shop just north of Boston told me they don't open or close sunroofs when testing them, which I think is ridiculous. And, I had to convince them (like 3x) to elevate the rear of the car to better approximate my real life conditions. Buyer beware.
"Don't be fooled, she drives with the aggression of a scorned 17 year old"
Dunno exactly how the E46 looks (my E46 has the "megasunroof" feature) but for E39 the lines can get pinched under the trim such that they pass small amounts of water but overflow when it gets heavy. Testing with the roof closed is fine, although if you know what you're doing you can open the roof and gently pour water down the drain in question. But you can't expect that to flow unlimited water - even the most perfect factory setup you can overload doing that and then the tray overflows and leaks but its really "fine".
But, "Blowing out" sunroof lines is legendarily questionable because it can "blow off" connections on the hose. You can use air but you want to do it judiciously and there's some other tricks you can use (like putting the air into a long hose that then threads down inside the factory tube so the pressure gets past the first joint... ) The other tricks are a stiff weed-wacker cord to roto-root.
If its front corner / A-pillar that's pretty easy to access, pull the trim, worst case pull the front corner of the headliner down without removing...
2003 M3CicM6 TiAg
Former:
1985 MB Euro graymarket 300SL
Good info. I've used weed trimmer cord also.
BMW fleet...
2023 X5 4.0Xi
2012 F650GS
2007 F650GS
2006 F650GS
2002 325iT
1999 Z3
2003 530i (son's car)
1996 318ti (son's car)
Departed BMWs...2011 328i...2009 328i...2001 325i...1998 328is...1997 328is...1997 328Ti...
Hi guys some of you can help me for fleet elimination lambda probes and egr valve on bmw 330ci cabrio of 2000 170kw 231cv control unit siemens ms43 hw 7509942 sw 5101 help
Inviato dal mio VOG-L29 utilizzando Tapatalk
