Results 1 to 12 of 12
Thread: What transmission are you running on FI with 650+nm/480 ft/lbs?
    Apr 2015
    Copenhagen, Denmark
    318is turbo
    My M54B30 is parried with a g420 6 speed.
    My new setup is is gonna reach 650+nm and I need to upgrade my clucth which is expensive and I dont want to upgrade the "wrong" transmission.
    So what are you running?
    What transmission can handle this torque?
    Mar 2012
    Renton, Wa
    98 m3
    I’d grab a gs6-53
    1989 535i - sold
    1999 M3 Tiag/Dove - sold
    Feb 2012
    Birmingham, Alabama, USA
    1995 BMW M3
    480wtq? stock lol....
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    Getrag 420 will hold a while. ZF FS6-53 is rated 25% higher and BMW put it behind cars with way more than its 530 NM rating, like the earlier M5 twin turbo V8. It’s the best choice among the BMW trans options.
    Mar 2012
    Renton, Wa
    98 m3
    Quote Originally Posted by rajicase View Post
    Raj he is in Europe he has different options.
    If he is going to upgrade, he should grab a -53.
    1989 535i - sold
    Feb 2012
    1995 BMW M3
    I mean i guess. I wouldn't upgrade for 480. But if he just has the desire to..
    Sent from my SM-G900V using Tapatalk
    Mar 2012
    Renton, Wa
    98 m3
    Yeah I mean if you’re going to buy a nice clutch it’s cheaper to do it upfront before you decide to turn up
    1989 535i - sold
    Apr 2012
    Chicago, IL
    1987 325is
    420g should be fine. I'm using that with a DKM twin disc clutch. Haven't put it all together yet so I can't give feedback.
    Apr 2006
    Minnesota eh?
    86 325es
    There is no reason to upgrade that transmission.
    Mar 2012
    Renton, Wa
    98 m3
    Agreed, except if he wants to go with something stronger he needs to grab the -53 not a 420.
    1989 535i - sold
    Apr 2015
    Copenhagen, Denmark
    318is turbo
    Ok, well I have a 420 now.
    But a gs6-53 is only 1000 USD which is nothing compared the the clutch and hassel.
    https://www.ebay.de/itm/BMW-6-Gang-S...sAAOSwKwBbDEFF
    What about fitment?
    Do anyone have any experince with Clutch master FX series?
    m3mods's Avatar
    m3mods is offline Boost Addict BMW CCA Member
    Sep 2011
    AC Schnitzer S3 CLS
    I have a like new (installed on a motor with bent valves and then removed) clutch masters fx850 twin disc setup with the billet flywheel option as well as their sintered iron discs I might part with. The sintered iron discs aren't listed on their site so you have to call them for details. They hold significantly more torque than both the organic and ceramic disc options.
  1. what width are you running on your E36?
    By whoshaunq in forum Tire & Wheel Forum sponsored by The Tire Rack
    Last Post: 06-25-2012, 10:37 AM
  2. What chip are you running on your 540?
    By DOC540I in forum 1988 - 1996 (E34)
    Last Post: 04-30-2010, 01:46 PM
  3. What centercaps are you running on your Kosei K1s?
    By old skool in forum BMW Rides & Events
    Last Post: 04-24-2009, 04:43 PM
  4. What exhaust are you running on your M3?
    By Lytheum in forum 1992 - 1999 M3 (E36)
    Last Post: 03-09-2009, 11:07 PM
  5. Replies: 24
    Last Post: 03-31-2008, 12:23 PM
