SOLD:: DASC Downing Atlanta Supercharger kit for M42/M44 engines. $2000 shipped, or best offer.
Kit originally from E36 chassis so it should fit 318i, 318is, 318ti, Z3 models with 4-cyl engines. Will fit an e30 but more work is needed. This has been in my storage for a long time. It was bought it with the intention of fitting it to my M42 e30 318is but never got around to it. The kit came from an e36 car and it for a serpentine belt setup. If this is to be installed on an E36 then I'm pretty sure it needs a BMW throttle cable from a right hand drive vehicle. This is due to the setup placing the throttle body in a different position.
Supercharger lobes have a couple small scratches but look to be in good condition (video below). The gaskets between intake manifold to supercharger and supercharger to intake elbow need to be replaced (I disassembled them to inspect supercharger). DIY gasket paper will work. A couple of smaller hoses have some cracks at the ends. They are not specialty hoses and should be easy to trim or replace. Everything else could use a good cleaning but is in decent condition.
Also comes with new phenolic intake manifold spacer, longer studs and gaskets (helps reduce temperatures and heatsoak). I've also got digital copies of two install manuals and packing lists for e36 kits.
PM me for manuals, packing lists, more pics, questions, etc.
Ignore the second supercharger, I dont have it anymore.
Youtube vid of supercharger lobes:
https://youtu.be/hEKxdcPW-Ss
do you still have it??
