A lot was invested into this car all within the past year to make it my perfect E46 M3 - it's well sorted with a select quality part. It's my daily and driving 70 miles a day, I'm looking for something bigger and possibly DCT. This is my 3rd E46 M3, owned for a year and maybe the last one until I can afford to have a dedicated track build.
Reference:
Carbon Black M3 Sale Thread
Alpine White M3 Sale Thread
History:
I believe 2 previous owners, both BMW enthusiasts.
Previous sale link here
Norcal/Socal car, with one year spent in Spokane, Washington.
Garaged, never driven in snow.
Car itself is in great condition, both interior and exterior. Paint is in great condition, no accidents, frame damage or rust. Interior is nice, leather shows minimal wear and all panels look good. Front bumper can use a respray. Sunroof is functional. A/C blows cold, stereo sounds superb, seats function, auxiliary items such as defrost, wipers, lights, gauges all work as intended.
2002 BMW M3 Steel Gray
- Black Nappa Interior
- Heated Seats
- Sunroof
- 6MT (SMG to 6MT Conversion by Garage 54 @140k)
- 152k
- Clean Title (Title in hand)
Exterior
OEM Headlight Lenses
OEM Clear Corners
OEM Tail Lights
OEM Side Markers
OEM CSL Trunk (Glasurit paint by Pacific BMW)
OEM Hood Vent
OEM Gloss Shadowline Window Trim
OEM Windshield Trim
Osram 66240 CBI (5500K)
LED Reverse Lights
Color Matched Kidney Grills
Color Matched Reflectors
Gloss Black Side Grills
Rear Fenders shaved by Tony
Mechanical
RTD Short Shifter
RTD DSSR
Rogue Engineering Transmission Mounts (Street)
Rogue Stainless Clutch Pivot Pin
Rogue Engineering Clutch Line
Dinan Throttle Bodies
Dinan Strut Bar
K&N 57 Series Intake & MAF Screen
AP Headers
High Flow Metallic Catalyst
Beisan Vanos Complete Overhaul (Anti-Rattle, Hub, Sealing Plate, Viton Seals, Bolts)
OEM Exhaust Upper Chain Guide
OEM Machined Bell Housing & Detent Springs by Kaiv
Suspension
TC Kline S/A Coilovers
Ground Control Street Hybrid Adjustable Camber Plates
Ground Control RSM
Ground Control Weight Jacks
PowerFlex Hybrid FCAB
PowerFlex RTAB
Hotchicks Adjustable Endlinks Front
Apex 75mm Extended Studs/Nuts
OEM Wheel Bearings
Wheels
Beyern Spartan 18x9.5 Chrome
265/275 Federal SS595 85% Thread
Interior
Piano Black Trim
CF Door Handle Trim (Front & Rear)
CF Lower Steering Wheel Trim
BMW Motorsport "Golf Ball" Knob
OEM A/C Pillars
OEM Center Console
OEM Cup Holders
OEM Center Storage
OEM Radio Faceplate
OEM Aux Adapter
ECS Clutch Stop
Audio
AudioControl LC7i
Alpine MRV F300 (4ch)
Alpine PDX F4 (4ch)
Image Dynamics ID12
Stereo Integrity M25 Tweeters
Maintenance
Valve Adjustment
Rob Bearing Recall via BMW
ICV Flush
OEM Intake Camshaft Position Sensor
OEM Exhaust Camshaft Position Sensor
OEM Throttle Position Sensor (Both Sensors)
OEM Clutch
OEM Shifter Bushings
OEM Valve Cover Gasket
OEM Clutch Fan
OEM Guibo
Essentially all transmission components (bearings, compression springs, pins, seals) were replaced during the 6MT swap
OEM Engine Mounts
OEM Fuel Filter
OEM Fuel Pump
OEM Cabin Filter
OEM Final Stage Unit
Hunter 4-Wheel Alignment
Accessory Belt
Motul Transmission Fluid
Oil/Filter every 5K using TWS
Blackstone Oil Report (see below)
The Bad
Front bumper needs fixing - the bracket comes lose and paint has seen better days.
Front passenger fender liner needs replacement.
Front brake rotors will need replacement in near future.
Rear subframe will eventually need to be reinforced.
Included
ACS Roof Spoiler (Steel Gray)
OEM Trunk (Steel Gray)
Color Matched Hood Grill
(2) Beyern Spartan Chrome 18x9.5 with 275/35/18 595SS Tires - Brand New - Was planning on attending a car control clinic, but haven't.
Asking Price $20k
