Results 1 to 6 of 6
Thread: how to clear active steering malfunction light with software?
    Chicago, Illinois
    2004 530i
    My active steering works fine, steering wheel angle is also fine, but the light on my dash is stuck, maybe due to a bad sensor. I've tried turning the wheel left and right, with both the motor on, or just the ignition on, I've tried slow driving with turns, long distance driving, it doesn't reset. I have a new battery, and I've topped of power steering fluid, nothing. Is there a way to clear it in INPA, DIS, or SSS progman?
    I've tried clearing error codes with INPA, but the active steering light still stays on.
    Under the active front steering menu (AFS) in INPA, I get the following error codes: 612c 70 hardware error control unit; 614a 30 engine position angle not initialized
    If you haven't fixed the problem, how would clearing the light be a solution?
    Osnabrock, ND
    2004 325xi,2004 545i SMG
    you will need to run the test plan and re calibrate the Active steering.
    Level 1 Certified BMW tech.
    Wadsworth, Ohio
    BMW
    The BMW software toolkit you have should be able to scan and release info on the sensor.
    If it hasn't failed as 90turbo1 said you're going to need to do the test and recalibration settings via software to clear the code.
    Chicago, Illinois
    2004 530i
    I have INPA and DIS, and about to install Rheingold. Where do I go under INPA or DIS to do this? My active steering works, the error light cannot be cleared via INPA.
    Jun 2008
    Halifax, Nova Scotia, Can
    2004 E60 545i
    Answered you on the other forum.......
    ">'85 Mlite E30, '98 E36, 1998 528i, 5 spd manual, black on black, sold in 2012 and still going past 350Kkms, now MYSTIC Blue 2004 545i, 6 spd Steptr., Adaptive steering and Xenons, Anti dazzle mirrors. Aux+Belt-Chime+Dig speedo+iDrive discl. 2007 TCU+BT Coded+Sure BT Board
  1. How to disengage my airbag malfunction light?
    By kmac47 in forum 1999 - 2006 (E46)
    Last Post: 06-12-2013, 01:45 PM
  2. How to clear abs, oil etc lights
    By MRBMW85 in forum 1999 - 2006 (E46)
    Last Post: 04-18-2013, 10:00 AM
  3. How to clear oil service light with OBD II scanner
    By jokergerm in forum 1996 - 2003 (E39)
    Last Post: 05-04-2007, 12:31 AM
  4. How to remove a steering rack with no tools...
    By OptimusGlen in forum 1983 - 1991 (E30)
    Last Post: 02-19-2006, 11:14 PM
  5. How to clear the check engine light?
    By wysockib in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 06-06-2005, 10:18 PM
