So I need some help diagnosing a strange noise... Car is a 2002 325i w/ 205,000 miles, 100% stock. At first I thought it was just coming from the AC but the noise occurs even without the AC on. It is a hissing sound that is present at all times, except under acceleration. It almost seems to "cycle" at idle, if that makes sense. Weird thing is that when coasting, and very lightly tapping on the brake, the hissing lessens slightly with each tap, but doesn't go away completely if I am braking. The only time it goes away is under acceleration. I've got a couple videos for ya. The one from inside the car demonstrates the acceleration vs coasting.
Inside car under acceleration, then coast: https://www.youtube.com/watch?v=-S_D7-Usndw
Under hood @ idle with throttle input: https://www.youtube.com/watch?v=k4YM9YSiZD0
CURRENT:
18' F22 M240i | 6MT | MGM/CR
02' E46 325i | 5MT | SBM/B (200k+)
SOLD:
10' E82 135i | 6MT | BSM/CR
03' E46 330ci | 5MT | JB/B
Not really related to acceleration, but since it changes while braking; it might be a vacuum leak, possibly the brake booster.
Does the brake pedal seem harder to press than normal?
Edit: this seems to tell the same story: http://forum.e46fanatics.com/showthread.php?t=1018617 (faulty brake booster)
No change in performance/feel with acceleration or braking. It only slightly lessens the noise when tapping the brakes but then doesn't get any quieter from there. I did a couple quick stops from 50-20 and then 30ish to 5 or so, just for fun to see if that worked ha. Almost seemed to make it louder afterwards.
I'll have to check out that thread. Thanks!
CURRENT:
SOLD:
Brake booster looks like a real pain in the *** to replace! Good luck..
I'm not sure if that's what it is. Reading through that thread it seemed like their noise got louder with the brake pressed. Mine is the opposite. But the noise seems to be coming from the same place. Also, I have no codes or changed pedal feel either... Hmm. I'll stay tuned to see if anyone else has any bright ideas lol. Luckily this isn't my car, and just a loaner until my M240i finishes production. But I'm trying to help the owner out with stuff while I have it. 16 year old kid just got it given to him by his dads work friend who was the original owner and put 200k+ on it. Pretty amazing. This is the only issue I've found in 2 months of driving it, other than one of the keys went bad.
CURRENT:
SOLD:
Disconnect the vacuum line from the booster and cap it off. If the noise is gone then it's the booster. Don't drive it like that though, you won't have power brakes.
Sent from my SAMSUNG-SM-G870A using Tapatalk
Smoke machine
_________
1980 320i - Kashmir Metallic - Sold in 1993
1985 535i - Cosmosblau Metallic - Sold in 1995
1985 535i - 1985-06 - Delphin Metallic - Sold in 2016
1983 320i - 1982-09 - Kashmir Metallic - Currently own!
2004 ZHP - 2003-08 - Titanium Metallic - Currently own!
2000 M5 - 2000-02 Titanium Silver - Currently own!
There is a vacuum hose that goes into the booster near the master cylinder. It is a relatively large line (for a vacuum line) that goes to a check valve. The check valve is either straight or 90 degree and goes into a rubber grommet on the front of the booster (master cylinder side) and can be pulled out of the booster and capped/plugged. You can even have someone else put a finger over the end. There is also a suction jet pump in the line to the engine which can leak but it's under the hood. If you hear a vacuum leak INSIDE the car and the noise changes when applying the brake I would bet on a leaking booster. If the noise is gone with the vacuum disconnected it's confirmed. If it's still there try to locate by ear or do a smoke test. Do you have a CEL on and lean codes?
Pull out #3 (check valve) and cap/cover/block or use hose pinching tool on the rubber hose #2
Awesome info. Much appreciated!
After leaving work last night, I did some more "testing" and the hissing completely goes away while stopped with the brake pedal firmly pressed. I think you guys nailed it on the brake booster. I'll do some troubleshooting that randy laid out and keep this thread updated for any future searches. Thanks!
Oh by the way, I do NOT have any codes being thrown. The hissing just started probably 2 weeks ago or so. I had just assumed it was the AC since its been on practically full blast since then.
CURRENT:
SOLD:
