Hello all,
everyone else has a build thread, figured I would make one too. The others helped me figure out what directions to go considering I didn't buy the kit new and had to figure out a lot of things on my own. The car is a 1996 328i black on tan interior (hate the tan). Motor is a S52 with under 40k on it. I just finished this thing today, and just need to get some fresh fuel for it and will run it tonight after work. My biggest fear is that the stock compression will give me issues on 92 octane gas, I think it will be around 10psi but we will see...
ENGINE:
S52 motor- Stock compression with ARP head studs and OEM HG
RMS stage 2 SC kit- Vortech V1 W/ 3.333 pulley
Rally road top mount oil line
Clutchmasters clutch / lightweight flywheel
M50 manifold- DIY W eurosport TB plate
803 MAF/ 60lb injectors
RK tunes remote tune
TMS catch can
Rally road 255lph fuel pump kit
EXHAUST:
SAP delete
TMS shorty headers
Bimmerworld track pipe
Supersprint cat back
SUPSENSION:
K sport coilovers
Status Gruppe adjustable end links
ALL ball joints replaced
95 M3 control arms
UUC poly engine mounts
UUC poly subframe bushings / Welded rear subframe reinforcement
ECS poly diff mounts
UUC poly RTAB
TMS adjustable rear camber arms
UUC adjustable sway bars
DRIVETRAIN:
new OEM driveshaft
Z3M short shifter w/ ZHP knob
Absent racing 40% 3 clutch LSD 3.23
Style 68 E46 17 in wheels (square, all 4 are rears)
APPEARANCE:
100% Stock
I do have an m3 bumper that will go on after I get paint, if ever...
Probably forgetting a few things, but that's the most of it! I will try to post some pics here soon!
Nice setup!
In before the "get rid of all of that and go turbo" posts.
I ran that setup on stock compression and stock headgasket for about 10k miles at 12.5psi on a bad AA tune and it held together. I think 10-11psi on 92 octane and such low miles you should be fine.
'98 RMS stage 2+++++(491whp/390tq VAC cams, CES Cutring-9:1, Built blower, Meth etc)
'09 Saab 9-5 Combi 5mt 1 of 1(Built Motor, Brembos, LSD, the works!)
'22 Cadillac CT4-V BlackWing 6mt
'22 Cadillac CT4 2.0T Sport AWD (wife's)
That makes me feel better Jamesons! I have driven it about 50 miles, still sorting out a couple issues, think my 02 sensors are bad, or at least one. BMWlogger data shows that bank 1 and 2 are doing very different fuel trims.
My goal now it to keep working with Jordan at RK to get the tune dialed in, pretty sure the 02 is my issue... I will update soon!
I already wish I went turbo, BUUT twins are on the way and I will be happy just getting this running perfect at about 400whp. Woman wants a lexus lx470 aka no turbo for me
