Hi All,
I am helping my mother with her newly acquired Electric Red 525iT (yes, it is a 5 speed). She lives in PA and the car will see some winter use. I was going to pull the rear plate filler panel and just use a bracket to attach the plate so the filler won't hold the salt in. Does the newer BMW E60/E90 plate holder work? I will need to get some plugs for the EU plate holes as well so i will start searching RealOEM or just re-use the filler plate plugs/grommets.
I am curious on everyone's thoughts.
Thanks!
Wade
No one...?
Wade
I did the filler plate delete on my 540it— what I did was cut the plate filler all around so it just had enough surface area to mount the plate. With the plate mounted, it's invisible and looks like a Euro plate setup but still uses the normal US mounting bolts. It's a pretty clever little hack.
1995 525i 5-speed - Thread
Thanks!! That is what I was looking for. I might pickup another filler panel and do that then. The PA salt can be nasty so I would like to give the car a fighting chance.
Wade
That's what I did with my old touring as well.
wow, that is an extremely cool mod.
Quick update...
I grabbed the E46/E90/E60 rear plate bracket for US plates. It works with the holes in the grommets that keep the filler panel in place. Remove the filler panel, put the grommets back in and then screw in the bracket (it only goes in one way, FYI). I mounted the US plate and was all set.
The added bonus here is that it puts the plastic bracket between the painted edge of the plate cutout on the tailgate and the back of the plate. Hopefully this will cut down on damage to the paint in that area.
Lastly, a Euro plate can be screwed in behind the US plate on the bracket as not to touch the paint but add some interest. Just throwing this into the mix since it uses all OEM parts.
Wade
Any tricks / tips to remove the filler plate?
Sent from my iPhone using Tapatalk Pro
