Results 1 to 19 of 19
Thread: M62TU Summer Project
    Apr 2017
    New York
    2001 540i 6MT
    Talking M62TU Summer Project
    Hello all! Fairly new here, posted/thread started a couple times, but this will be my first thread that I plan to update and keep up to date as I progress in my summer project. I purchased most of the parts already, just sitting in the garage waiting to go in! I'll do my best to keep everyone updated with pictures and progress once things get completed.
    The Car - 2001 540i/6 with 100k miles on the clock. Already did a full M5 drivetrain swap (Driveshaft, Diff and Axles). Below is the list of things I plan on doing.
    - Pull engine with transmission [COMPLETED]
    - Timing chain guides and chains (everything else that's "in there" (oil separator, tensioners, etc.)) [PURCHASED]
    - Complete reseal of all gaskets and o-rings [PURCHASED]
    - Replace a couple of "cheap" sensors (oil pressure, coolant level, etc.) [PURCHASED]
    - Replace Oil pump, Chain, Sprocket [PURCHASED]
    - Reseal/build VANOS units
    - Replace Engine/Tranmission mounts [PURCHASED]
    - Replace all pulleys, tensioners, belts [PURCHASED]
    - Replace clutch (undecided about a lightweight flywheel+clutch kit)
    - Replace all power steering lines and reservoir [PURCHASED]
    - Replace Centerlink and tie rods [PURCHASED]
    - Eibach sway bars (front and rear)
    - Zionsville Radiator, shroud and eletric fan upgrade
    - M60 Intake manifold [PURCHASED]
    - BC Racing Coilovers [PURCHASED]
    - Send heads to machine shop (new springs and valve stem seals)
    Not sure if I want to touch the block (crank/pistons) although I am replacing front and rear main seals.
    Possible upgrades, maybe in the future after I finish the above
    - Schmiedmann Headers (undecided how I would run rest of exhaust)
    - VFE Supercharger
    Planning on this taking me a few months as I still need to order some parts. Looking for any and all suggestions, tips, etc.
    Jan 2015
    Tempe, AZ
    1995 525i/5
    Sounds like a fun time! I wouldn’t bother with the head work though, these engines aren’t known for wearing out springs or valve stem seals, the valve stem seals are only an issue on the N62/N63 motors. I’ve pulled heads with 249k miles that looked fine, so I think you’re okay at 100k miles.
    1995 525i 5-speed - Thread
    Mar 2017
    Lynchburg, VA
    2001 540i
    Looking forward to it, lots of pictures please!
    2001 Salvage Title 540i
    My build thread: https://www.bimmerforums.com/forum/s...toive-decision
    Apr 2017
    New York
    2001 540i 6MT
    Quote Originally Posted by dannyzabolotny View Post
    Hmm that's surprising! I was told from a co-worker mechanic (not a bmw tech) that if I plan on supercharging, valve steam seals are good thing to replace. Knowing this, it would save me a lot of cash not sending out my heads.
    Jan 2015
    Tempe, AZ
    1995 525i/5
    Quote Originally Posted by Roxie View Post
    On some cars with looser tolerances it's a valid point, but the M62tu heads are actually really solid. A lot of guys on here have superchargers on theirs with higher miles and no head work. Given that you have just 100k miles, I wouldn't worry about it. If you want to play it safe, do a compression and leakdown test to make sure everything is where it should be, and if everything looks fine then I'd leave the heads on.
    Mar 2012
    Lansdale, Pa
    98 540 6, SC'ed, 16psi
    No need to do the head work as Danny said. My car has 167k on it now with the last 35k being supercharged. No issues at all with the heads or anything. Block has never been opened. I just did timing chains and associated gaskets at around 120K. My car runs great.
    Also, no need to do the oil pump unless its all scored up inside. Mine looked like new when I took it out just ot have a peek at its insides.
    Long Beach, CA
    '01 M-Sport/'01 986
    You seem to know a lot about the M62s, were you a tech before?
    I've only tackled a few things on an m62tu, like valve cover gasket, motor mounts and some electrical stuff.
    Join the SoCal E38 owners group on Facebook http://facebook.com/groups/officialdistrict7
    ... and on Instagram
    @district7_socal
    Subscribe to my YouTube for E38 content-->
    https://www.youtube.com/c/ARPerez
    geargrinder's Avatar
    Mar 2010
    AndoverRockport MA & Intl
    E46M3Cic E39.540iT E84X1
    Alread did a full M5 drivetrain swap (Driveshaft, Diff and Axles).
    FWIW, some will read "full drivetrain" as more than just the diff stuff... I know technically you're correct, but... seems like gearhead laymen use for a 'drivetrain swap' they guy 9 times out of 10 means "motor and tranny and the whole shootin' match". Seems to be one of those "industry" vs "hobbyist" things... colloquial use - aka hobbyists don't say "Powertrain" too often...
    Yeah, I would NOT EVEN THINK about worrying about the heads unless you have some real evidence otherwise. I would almost call them bulletproof. Valvetrains are super robust, aside from the documented VANOS issues... the only blown heads we see are crazy abuse situations. I mean if you were going crazy build and wanted stiffer springs in there or something, that'd be one thing, but, that doesn't seem on the agenda in this case.
    I love LWFW myself but there's people all over the map on that. If you're sensie about noise at idle and stop lights and whatnot... you won't want it. Driveability of the LWFW is fine, on this motor it doesn't make the car tricky to launch or anything, and it makes the revs WAY more satisfying than the big ol' DMFW boat anchor. As long as you don't pick a crazy clutch you adapt to the drivability in about 5 minutes.
    With all the stuff you're doing, you probably want to put an M5 steering box in when the engine is out. Transforms the steering pretty well.
    2003 M3CicM6 TiAg
    Former:
    1985 MB Euro graymarket 300SL
    Apr 2017
    New York
    2001 540i 6MT
    I've read a couple times that the flywheel (DM) needs to go on the same way it came off, so its "timed correctly" with the starter if i understand correctly. Does this also correlate to the (LWFW)? Also do you have any recommendations on LWFW+Clutch setup? JB Racing, UUC?
    Mar 2010
    Yes there’s a locator pin. Guys have bolted up FWs wrong anyway but if you’re half not retarded then it’s pretty easy to get right. Not remotely related to starter, it’s abiut crank timing. The FW provides the crank position shutters that the sensor reads back to the DME. Can’t use the M5 FW cuz it’s timing is off by some amount.
    JBR LWFW 100x out of 100.
    Clutches are different story. Lotta things you can try, ideally make sure it’s sprung hub clutch disk. I like my Spec 2+ but might go for 3 if I had to do over again because this Kevlar one is just a little squeaky when cold. Holds rock solid though.
    2003 M3CicM6 TiAg
    Former:
    Nov 2008
    M550iX, 540M-Sport, Scud
    My as well add the M5 rear traction rods too.
    2001 540 M-Sport (cdn), ST X (KW) coilovers, H&R 15mm spacers, Eibach anti roll bars (28mm/18mm), Beastpower rear antiroll bar brackets, M5 rear chassis reinforcements (traction rods), Strong Strut front upper strut bar, Dinan Stage 1 software, factory M-Audio subs, Bavsound speaker upgrade, Bluebus bluetooth integration, Stop Tech SS brake lines, ATE coated brake rotors, ATE ceramic brake pads.
    Apr 2017
    New York
    2001 540i 6MT
    Saturday (6/9/18)
    Hey guys, sorry I haven't posted in a bit, been busy with work and just the normal life stuff. Finally got around to starting the project this past weekend. I completely forgot about taking pictures until I took the headlights and front bumper off lol.
    So this was the start on Saturday (6/9/18)
    Bumper just got replaced and painted about a month ago, It has been be properly wrapped and stowed away until job is completed, just put it here along with my old one for the day.
    My buddy that I am borrowing the hoist and engine stand from finally called me around lunch time and I went to go pick them up!
    So I took a few more things apart before I called it a day, had to run out later in the afternoon to take care of some other things. So this is where I ended up at the end of the day on Saturday.
    Apr 2017
    New York
    2001 540i 6MT
    Sunday (6/10/18)
    Started Sunday morning with the engine harness removal. Got everything disconnected from the front/top of motor, then I slid underneath and disconnected everything from the transmission and the O2 sensors. Taped and marked all sensors just to avoid the headache of installation.
    While I was underneath, I went ahead removed the exhaust (cat back). Only disconnected the driveshaft from the transmission. After this I removed my shifter.
    This is just some of the crap I took out of the car, making friends with the fresh set of BC's that are going in once the motor is back in.
    At this point I was just double/triple checking my work to see if I disconnected everything so she would come out smoothly. Only real problem I ran into was header clearance. About halfway out I had to disconnect the driver's side exhaust manifold because it was hitting the steering column. Once I removed that, she came out nicely
    Apr 2017
    New York
    2001 540i 6MT
    As of now, Thursday (6/14/18) I am waiting on my "special BMW T60" socket so I can take my flywheel off so I can mount the motor on a stand rather than floating on a hoist. So everything is in my garage waiting patiently for me to start tearing down. Today I plan on going to the hardware store to pick up a couple bolts/washers for the stand. Socket should be here tomorrow so hopefully after work we can get things rolling!
    Mar 2017
    Lynchburg, VA
    2001 540i
    Great progress!
    JimLev's Avatar
    Sundance Mesa, NM
    00 540/6, '16 Highlander
    Might as well change the upper oil pan gasket too. The front part will probably break off when you remove the lower timing cover.
    Apr 2017
    New York
    2001 540i 6MT
    Already have it! I planned on bringing the entire upper pan to work and cleaning it in the parts cleaner, along with lower pan and all the timing/valve covers.
    Sep 2014
    Paradise valley AZ
    3 too many
    Hello Roxie
    Just read this thread,,,curious how it progressed and if youre finished with it. Thnx
    B M Whooplay
    Apr 2017
    New York
    2001 540i 6MT
    Quote Originally Posted by BeeMWeeUp View Post
    Hello Roxie
    Yea sorry, kinda just fell off the wagon with posting here lol. Car has been done for a few months now. Running great =]
  1. I need your opinions for my summer projects!
    By Wildo2003 in forum 1991 - 1999 (E36)
    Last Post: 04-27-2006, 04:34 PM
  2. Hmmm, summer project?
    By Ghery in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 03-15-2005, 04:12 PM
  3. Nebraska Spring/Summer Project???
    By Mojo325is in forum Great Plains & Rocky Mountains - US
    Last Post: 01-12-2005, 01:34 PM
  4. List your Summer Projects for your car here
    By Preppy in forum Middle Atlantic - US
    Last Post: 06-28-2004, 09:25 PM
