Results 1 to 18 of 18
Thread: Squealing sound from engine compartment
    Nov 2014
    Vena, Sweden
    1992 BMW 850ia
    Did take out my 850i -92 from winter storage a few weeks ago. Did check all various fluid levels and found that the hydraulic oil was low so I filled it up. Then when driving there is a squealing sound that occurs randomly and lasts for a second or two. It even happens when the car is parked with the engine idling. I don't know what this is and need help??
    Orlando, FL USA
    When my car does that, it's because the Pentosin fluid level is low or there's air in the system. Otherwise, all the belts are okay and not slipping...?
    Nov 2014
    Vena, Sweden
    1992 BMW 850ia
    Thank you Chris, air in the system. Has not checked that, will do.Before putting the car to winter sleep I did change the brake fluid, that is about 6-7 months ago. I never checked the hydraulic fluid at that time. Now, reading about how to bleed the hydraulic system I realize that my car has ASC+T which demands the disconnection of its control unit. Where is it placed?
    Mar 2008
    montreal,Canada
    bmw 850
    I have asc+t and never heard of disconnecting anything, i always use the nipple to bleed the system. Interested to hear if there is some other steps i need to follow.
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    The CHF11S (Pentosin) circuit is separate to the brake system - and that is bled by turning the steering to full lock (left and right) a few times.....
    My BMW Repair YouTube Channel
    May 2013
    Salinas CA.
    1993 BMW 850CI
    Idler pulleys
    Quote Originally Posted by peake View Post
    Have you checked the idler pulleys?
    Nov 2014
    Vena, Sweden
    1992 BMW 850ia
    The pulleys are brand new.
    Nov 2014
    Vena, Sweden
    1992 BMW 850ia
    Now I have removed all air in the hydraulic oil system. It took several tries were I turned the steering wheel, with the engine running, from left to right extremes. At the end it only came clear oil. The squealing is gone but what is more remarkable is that the ABS, ASC and +T works like they never did before. I also checked the ASC "stomp" code and it did show a funny error in the beginning ( code 17 error). After a test run it shows code 1 meaning no error. I'm happy.
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    Great news!
    Nov 2014
    Vena, Sweden
    1992 BMW 850ia
    Even better news, today I found the real cause of the noise. It was the A/C and probably the expansion valve that makes the noise which has been absent since the last time I wrote in this thread. Today it showed up again but this time when I turned the A/C on. It disappeared in the same second as I turned it off again. Why it does this I don't know.
    Nov 2014
    Vena, Sweden
    1992 BMW 850ia
    Now I have found out the origin of the noise. It was in the A/C system but not the expansion valve as I guessed from the beginning. It is the auxiliary pump, pumping hot cooling fluid into the A/C machinery. This it does to heat up the cooled air coming in from the first stage in the A/C system to let the output air have the right temperature compared with the temperature setting on the control unit. My A/C and therefore my auxiliary pump has not been working for many years (> 6) and because of that the pump was not "lubricated" and made all the noise. But after a couple of thousand kilometers it slowly stopped. The A/C is now working and keeps the temperature fairly constant. But at the same time I am worried that the pump is broken!? How can I check that the pump is ok?
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    Here's some info - I've done without an auxiliary water pump for many years now:
    https://www.meeknet.co.uk/e31/AuxPum...mp_Repairs.htm
    https://www.meeknet.co.uk/e31/E31_He...eplacement.htm
    Calgary, Canada
    '91 E31 850i,'05 E53 4.4
    Quote Originally Posted by razman850 View Post
    https://www.bmwtechinfo.com/repair/main/721en/index.htm
    go to the Brakes section in the Contents page, then look for the ASC+t bleeding (7 lines from the top) and click it. Read here how you need to disconnect the harness to the module/unit, which is under carpet, under left door sill. TIght area but doable.
    I swear, my cars are like a girlfriend.
    Sometimes its a rough ride, sometimes its smooth motorin'.
    Sometimes she doesnt like how i treat her and sometimes i dont like how she behaves.
    BUT at the end of the day, she loves it when I am inside her.
    Jul 2015
    Melbourne, Australia
    1994 840Ci - M60, 6MT
    Quote Originally Posted by Timm View Post
    Do you have more info on this?
    Jun 2013
    Auckland, NZ
    1994 E31 850CSi
    Quote Originally Posted by tangcla View Post
    Go to Chapter 32 - Steering, sub-chapter 32-13-006
    Current:
    1994 E31 850CSi Sterlingsilber/Anthracite Buffalo
    Previous:
    1987 E28 M5 Delphin
    1986 E23 M745iA Arctic Blue
    1986 E24 635CSi Polaris
    1976 E3 3.0 Si Arctic Blue
    Calgary, Canada
    and if you have the asc+t then you have to bleed the pentosin system using the bleeder screw in engine bay with the ASC+t module unplugged (interior, left side, under door sill) as explained in the link I posted a few comments up.
    Nov 2014
    Vena, Sweden
    1992 BMW 850ia
    What happens if you don't unplug the ASC+T module when you bleed the pentosin circuit?
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    Nothing as far as I know - I've always bled the power steering system by running the steering from lock to lock a few times:
    https://www.meeknet.co.uk/e31/BMW_E3...ter_Change.htm
  1. Squealing sound from engine (intake manifold area) at cold start
    By BMWknight in forum 2001 - 2006 M3 (E46)
    Last Post: 03-15-2013, 03:07 PM
  2. weird chug chug chug sound from engine compartment
    By danheit in forum 1995 - 2001 (E38)
    Last Post: 01-29-2009, 08:36 PM
  3. Ticking sound from engine compartment
    By thekaiser in forum 1991 - 1999 (E36)
    Last Post: 05-17-2007, 01:59 PM
  4. clicking sound coming from engine compartment
    By sealman202 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 09-22-2006, 03:36 AM
  5. 540 Squealing noise from engine compartment
    By kbjohan in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 07-13-2004, 11:22 PM
