Bimmerforums Upgrade Garage The Tire Rack
Results 1 to 4 of 4
Thread: Anyone running 245/40/17s?
    Avon, CT
    7/94 M3, 92 325-4
    Hi,
    Any clearance issues? Car is a 95M3, H&R OEM Sport Springs, Konis, Stock Brakes, 17x8 ET 40 OZ wheels, square set-up. I have no desire to roll the fenders.. It's basically street use with an autocross or two thrown in.
    Thanks in advance!
    'But Dad.... it's PURPLE!'
    Aug 2013
    1999 BMW M3 Coupe
    I run them on 17x9 ET42 wheels with no issues, so you will be fine. Haven't touched my fenders. I run a 12mm spacer in front to clear the struts, but you may not have to with 8 inch wheels and a lower offset. The rears will certainly be fine. Mine are a relatively tight fit at -2 degrees rear camber and a lower-than-stock ride height, but no rubbing and no fender roll. Your wheels are an inch narrower than mine, and my tires are also very wide 245's (among the widest non-slick).
    Apr 2015
    Tennessee
    1998 BMW 328i
    I run them on 17x8 et40. The 245/40/17 is the stock tire size for the M3 rear. Fronts fit just fine on the wheel specs I listed.
    Avon, CT
    7/94 M3, 92 325-4
    On 1995 M3s stock size is 235/40/17 front and rear. I did have 245/40/17 Pilot Sport 4s installed front and rear with the set up listed in my first post. No changes to alignment and no issues at all - even though tires are a tad taller. The tires are spectacular and I'd recommend them to anyone.
  1. Anyone running 245/40/17's?
    By about6 in forum Tire & Wheel Forum sponsored by The Tire Rack
    Last Post: 04-25-2011, 08:49 PM
  2. Can I run 245/40/17 all around on a 97 m3?
    By pak in forum Tire & Wheel Forum sponsored by The Tire Rack
    Last Post: 05-27-2004, 11:03 PM
  3. for those running 245/40-17 all around
    By frKENm3 in forum Tire & Wheel Forum sponsored by The Tire Rack
    Last Post: 02-07-2004, 02:01 PM
  4. Can I run 245/40 17 Michelin Sports on 17X7.5 stock wheels?
    By ///Arman in forum Tire & Wheel Forum sponsored by The Tire Rack
    Last Post: 02-06-2002, 08:26 PM
  5. Anyone try 245/40/17 on front wheels?
    By Esteves in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 06-21-2001, 07:29 PM
