Searched for this and cane up empty handed, so I figure I'll post something to help anyone else that may be in the same boat...
My '94 (11/93) 325i had a damaged steering lock / ignition housing. I thought I did my research has correctly on RealOEM, and purchased a used housing from a forum member that was from a '97 E36. Everything fit, kinda of...
Looking back, it appears that the steering column made a change in '95. From what I've seen, it appears that the late model housing requires a column with a larger diameter. (Aprox. 46.5mm.) The late column housing on an early column was loose, rocking from side to side.
After placing spacers (~.030") around the column, everything sits nice and snug as expected.
James
Sent from my SAMSUNG-SM-G900A using Tapatalk
The only thing i know is the there are adjustable steering columns and non adjustable steering columns. Maybe you got the wrong part
the columns are indeed of different diameters as stated along with adjustable and fixed aspects.
