I’ve recently purchased a 1994 325i with an automatic and I’m currently going through and finding little things that need to be fixed. One of the things that I’ve found is that the shifter/gear selector (not really sure what to call it) slides from any postion with just a push. I’ve noticed that there is actually a button that is stuck. I’m assuming that it should pressed/pulled to shift positions but unfortunately that’s not the case. The other day I was playing around with it and I pulled the handle off. While looking inside I noticed a white plastic rod that looks like is snapped. There is also a pin up in the handle. I was wondering if anyone could give me the proper name so that I can look these parts up so that I can replace them. Or even a link for the parts. Is this a common issue? Thanks!
Hello and welcome to the forum Jason! Please feel free to give us a call at 888-280-7799 and one of our BMW part specialists will be happy to assist you with the gear shifter part that you're referencing. I'm also attaching a link below to our site's DIY tech articles on the E36 platform if you're going to be doing any maintenance/work on it yourself. Hope this helps you out and let us know if you have any other questions!
https://www.pelicanparts.com/BMW/tec...h_main_e36.htm
888.280.7799 | 6am - 5pm PST
item 02 PULL ROD L=121MM 25161219755 is broken/snapped, replace it http://www.realoem.com/bmw/enUS/show...diagId=25_0580
