Results 1 to 3 of 3
Thread: Heat and air don't work
    Columbus, OH
    E46 M3, E83 X3, E90 328X
    I have a 2005 E83. Late last year, my A/C went out. I didn't think much of it, didn't make a point to prioritize diagnosing. Later that winter, I realized that my heat stopped working.
    The electronic panel still works and the blower motor blows air. In all cases, it appears to be blowing the current temperature of the air.
    I understand how to diagnose these systems individually. Is there a failure in this vehicle that would affect both systems?
    Thanks,
    Warner
    Aug 2009
    Lake Arrowhead, CA
    75 BMW 2002, 82 320
    I went on line for a fix for the A/C, I also have a 2005, not putting out cold air and found a suggestion to disconnect the main wiring connection for the HVAC head end unit. Something about powering down and resetting the system. It worked, the A/C is again working but the system is still weak.
    The defroster will put out cold air with the temp set at it's lowest setting, something is going on but not sure what to try next.
    David
    Aug 2009
    Lake Arrowhead, CA
    75 BMW 2002, 82 320
    Update on our 2005 X3: I stopped at my local parts store and with the addition of about a third of a can of R134 I now have AC that is putting out cold air.
    They had the gage/hose/trigger that they loan you. With the car running and the A/C system on, you set the ambient temperature on the gage then pull trigger.
    Again, I did not use the whole can.
    David
  1. will an auto-x work well for heat cycling?
    By ///Mracer in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 03-09-2004, 08:58 AM
  2. What work today is not necessarily going to work tommorow
    By tryme96Z in forum 1983 - 1991 (E30)
    Last Post: 11-03-2003, 08:38 PM
  3. Poll: NWS clickers at work? (work safe)
    By SR20Fastback in forum Off-Topic
    Last Post: 05-06-2003, 02:21 AM
  4. Replies: 0
    Last Post: 12-17-2002, 03:06 PM
  5. Heat doesn't work!
    By saitam in forum 1991 - 1999 (E36)
    Last Post: 08-13-2002, 09:54 AM
