Results 1 to 4 of 4
Thread: Crankcase vacuum; Unmetered air?
    Lexington, KY
    99 Coupe Hell Yeah Red
    My Z3 coupe has a Vortech SC (6psi) and I have had MAF and O2 sensor codes ever since it has been installed. Car runs fine and the plugs look perfect. My question is: Since the crankcase positive pressure is pulled back into the pre-SC intake and after the MAF, does this mean that there might be enough un-metered air entering the intake after the MAF to cause error codes. Since the MAF is there to determine the amount of air intake, it seems that the air entering the intake after the MAF might confuse the system.
    I am getting rich codes for both banks and a MAF error code. I have replaced the MAF and sensors but the codes come back.
    ....or might it just be the tune? It seems that VF Engineering is not known for their wonderful tuning re-programs.
    Any thoughts?
    Is running a vacuum to the crankcase absolutely required? I know it helps but have seen many FI builds just venting the positive crankcase pressure to the atmosphere.
    Feb 2009
    Arizona
    1998 e36
    Answer is simple, your MS41 is not tuned correctly. Also MAF does not like cone filter directly bolted on to it. It likes to see 6 inches of straight pipe in front of it for proper reading. Most of these FI kits are flawed in design
    Jan 2006
    Oakhurst, CA
    96 M3 97 M3 98 M3 99 M3
    Takes some pics of how you have it setup before we let Hakentt talk you into a tune you don't need.
    Lexington, KY
    Catch can pulls directly from valve cover (No CCV cyclone) and gets its vacuum from directly before the SC, after the MAF (hose connection shown). The filter is a bit further than 6 inches and the tube before the MAF is very slightly bent. I can easily get at least 6 in of straight pipe before the MAF with a small modification.
  1. Just a bit too much oil in the crankcase
    By WytLytnyn in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 02-02-2004, 05:07 AM
  2. F/I crankcase ventilation.
    By Keith97m in forum Forced Induction
    Last Post: 04-30-2003, 04:45 PM
  3. crankcase ventilation question
    By owen in forum 1992 - 1999 M3 (E36)
    Last Post: 04-28-2003, 07:18 AM
  4. Crankcase Ventilation valve?
    By Cheuk in Seoul in forum Forced Induction
    Last Post: 11-17-2002, 07:03 PM
  5. Anywhere on the block to get a Vacuum lead for my vacuum gauge?
    By LuxoM3 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 04-29-2002, 11:13 AM
