Results 1 to 25 of 32
Thread: 2003 540 m sport front bumper
    Feb 2018
    Alpharetta GA
    1995 ford bronco
    So just recently picked up this car and knew I had a check list of things to do to it. One of the first things was to replace the front bumper(torn pretty badly) and replace or refinish the hood(fairly large dent by the kidneys but my body man thinks he can fix it).
    I work as a svc advisor at a GMC dealer and my body shop told me they could get an M-sport front bumper aftermarket for about $260. I told him that an M-sport was totally different and he swore it was the right one. WRONG! Now he's telling me he can only find one through the dealer for $535. I normally stick to OEM parts all the time but I don't mind using aftermarket for a bumper cover. My questions are these
    1. I've found several aftermarket M5 front bumpers online for $250-300 will these bolt on pretty much??
    2. does anyone know of an aftermarket vendor that sells the stock bumper at a decent price?
    Thanks for the help. This forum is awesome!
    One day I'll get off my arse and post some pix, Sterling Gray on black 6-speed
    Jun 2015
    Tennessee
    BMW
    Aftermarket bumper has visible fitment issues where it doesn't sit flush with the fender at the wheel arch.
    the only thing special about your M-Sport is the T Bar at the bottom. This can be removed and put in a replacement bumper I think.
    May 2015
    Virginia
    E39, E39
    Thats is correct. The "tbar" ensurs that all your brake airducts are funcional. I have an aftermark m sport bumper with oem grill and tbar and it fits just fine.
    Sent from my SM-G955U using Tapatalk
    2013 Ford F-150 FX4 Ecoboost
    2002 530i/5 M-Sport
    1994 318i/5 (Up for sale Soon)
    Sep 2014
    North OC, CA
    01 M5 TiAg/M1SW
    Umnitza sells aftermarket bumpers, and they're active on the forum. They will also paint one to match and ship it.
    All - and I mean all - of the aftermarket bumpers have fitment "issues." They will bolt up perfectly fine, and accept all the factory parts and mounts and whatnot, but where the fender wheel arch "circle" crosses down into the bumper, there is generally a 1/4 inch gap on either side of the bumper. Nothing you can really do about it.
    Nate J.
    (oOO\ (|||)º(|||) /OOo)
    (eŌō\ (||||)º(||||) / ōŌe)
    Jun 2014
    B.C
    97 540 , 2000 323
    You can remove 10mm from the two crash bar mounts like I did and the aftermarket bumper will fit perfectly. Cut the horizontal tubing just behind the vertical crashbar bolt tube and weld back it up, simple. 1/2 hour fix.
    Oct 2012
    North Carolina
    2003 540/6 & 2013 X5
    I replaced my stock (silver) with umintza m5 aftermarket bumper. Was saving it in case I ever sold vehicle. I’m getting ready to sell car in the next couple of months. I would give you good price if it doesn’t go with new buyer.
    Sep 2014
    North OC, CA
    01 M5 TiAg/M1SW
    Quote Originally Posted by Astrocyte View Post
    I would not recommend modifying the front crash structure. That’s asking for trouble.
    Nate J.
    Jun 2014
    B.C
    97 540 , 2000 323
    If you lack skills maybe, no trouble on a 21 yr old car . What do you think auto body shops do to your car after a collision lol.
    Sep 2014
    North OC, CA
    01 M5 TiAg/M1SW
    Body shops should replace or repair damaged parts. And with the front impact shocks, I suspect they’d be replaced.
    Nate J.
    Jun 2014
    B.C
    97 540 , 2000 323
    Ok think about this, how do you think the vertical bolt tube is attached to horizontal shock tube? Oh ya its welded. Only difference is I lose 10mm of compression on a front impact. Either way, the car will be a total loss as these cars dont have a very high book value.
    Jun 2014
    B.C
    97 540 , 2000 323
    The impact shocks are only for an 8 or 5 mph crash anyways. I meant ti imply in the above reply that these parts are already welded from BMW , only difference is my welds look way better lol.
    Feb 2014
    Alexandria, VA
    ‘01 540’00 528T’03 525T
    Nate, what he did is no big deal. He just cut the bar stock 10mm shorter right behind the tube that the bolts go thru to fasten the reinforcement bar to the shock struts. The front end will still have the same absorption in an impact. Only difference is, you hit the other car a couple thousandths of a second later, than if you hadn’t custom cut the tubes, and your fake sport bumper cover had the bad fit. I did what he did on my 530, it worked great. Will be doing it on my 258 wagon soon, painting my fake new Mspoort bumper next week. Good part is, I work at a very good body shop, only gonna cost me a hunnerd bucks for paint and clear coat. Some dingaling hit the corner of my stock bumper last week, now that sheeeit pisses me off
    Jun 2014
    B.C
    97 540 , 2000 323
    I think its a big deal to people that have never welded before, its not like I'm modifying the space shuttle lol.
    Jan 2013
    orlando, fl
    2001 BMW 540i 6speed
    would you mind PM me where this is, im having same issue and would like to get my bumper to sit right lol.
    540i 6spd DUDMD tuned-weekend brute, sounds like an M5 throaty V8 "Vtec-ish" cam noise.
    Hummer- 35inch MT's, Adventure offroad package.
    check out my video gear
    https://kit.co/Lv5multimedia/mobile-videographer-set-up
    Best Oil hands down for bmw
    https://www.amazon.com/gp/product/B0...1441c0abde2552
    Feb 2014
    Alexandria, VA
    If you can’t figure out what we were talking about, maybe this might be a little over your head. As Dirty Harry used to say: “Man needs to know his limitations...”
    Sep 2014
    North OC, CA
    01 M5 TiAg/M1SW
    Quote Originally Posted by BimmrMeUpSnotty View Post
    True. And why I don’t recommend this for most people. If you can weld effectively, more power to ya. I can’t, and am jealous.
    Nate J.
    Feb 2014
    Alexandria, VA
    Welding is fun, anybody can be a good welder, all you have to do is get a good welder, welding gloves, a good welding helmet, if you are spending less than $400, you’re getting a crappy one. Common sense helps, make sure nothing nearby will catch fire from a flying cherryball, when done, if welding on a car, stick around for at least 15 mins, in case something will catch fire, you will be there to put it out.
    Practice, the more you get it, the better you get. Pick up scrap metal, different thicknesses will teach you volumes about proper penetration.
    Mar 2017
    Lynchburg, VA
    2001 540i
    This is a really good point. A decent mig gun is like a metal glue gun. You can become proficient very quickly. And steel is the way to go for at home shop fabrication. I get 1” x 1/16” wall square tube for less per foot than I can get soft as hell warped 2x4’s at Lowe’s. And you can slap together a table or a shelf or whatever far quicker, and you end up with something stronger and lighter. $700 - $1000 for an entry level mig setup is a tough pill to swallow, but I wish I had done it years before I did. Of course like anything else, the mig gun will make you realize you need a chop saw, then a tig rig, then a plasma torch, then a mill then a lathe....
    2001 Salvage Title 540i
    My build thread: https://www.bimmerforums.com/forum/s...toive-decision
    Feb 2016
    Destin, FL
    W220 S55 AMG, E39 540i6
    Someone should modify these bumper supports and sell them. I’d buy one.
    Chris
    04 Mercedes S55 AMG
    97 BMW 540i6
    Sep 2014
    North OC, CA
    01 M5 TiAg/M1SW
    Quote Originally Posted by cnsorial View Post
    That is a great idea, especially as they're bolt on.
    Nate J.
    Jun 2014
    B.C
    97 540 , 2000 323
    The only reason I mentioned cutting and welding ,is that the OP said he worked at shop and I figured he could tell bodyshop how to make a repop bumper cover fit properly. I have an OEM rear M5 bumper but my fake front cover fits better than the back, doing the weld mod. The real trick is making the non M5 brake ducts fit, but that is another story.
    Dec 2010
    Biddeford, Maine
    00 540_6
    Quote Originally Posted by douglawrence42 View Post
    So i went about it backwards?
    I got a drill press, the mill, a surface grinder, then the lathe, then a mig welder, and a stick welder..... Now I WANT a Tig machine.... and a good plasma cutter....
    Feb 2014
    Alexandria, VA
    Should have started with the TIG, harder to learn after figuring out MIG welding...
    Feb 2016
    Destin, FL
    Nobody wants to make me those modified shocks, huh? Haha
    Chris
    04 Mercedes S55 AMG
    97 BMW 540i6
    Mar 2017
    Lynchburg, VA
    2001 540i
    A local machine shop should be able to do the pair for $100 or less (usually $60-$80 an hour for manual work), should be less than an hours work. It’s definitely not worth my time to compete with that.
  1. E39 2003 525iT Sport (NC)
    By KRUZNBY in forum 5 series & 6 series
    Last Post: 05-22-2018, 09:37 PM
  2. Wtb: Sport Front Bumper 99-01 Sedan
    By BealeAss in forum BMW Parts Wanted
    Last Post: 01-26-2004, 12:52 PM
  3. M3 DAS Sport *CF* front bumper AND splitter
    By Alex McHenry in forum BMW Rides & Events
    Last Post: 12-29-2003, 08:29 PM
  4. Replies: 3
    Last Post: 09-17-2003, 01:42 PM
  5. E46 Front sport bumper
    By vimzin in forum BMW Parts For Sale
    Last Post: 04-23-2003, 12:47 PM
