Results 1 to 7 of 7
Thread: Removing light switch
    birmingham,al
    2001 3.0 Z-3 RD'STER
    Supposedly there's a tab on each side of the metal shaft of the switch to release switch...don't see them. Anyone offer help?
    Sent from my SM-G920V using Tapatalk
    birmingham,al
    Quote Originally Posted by MORRIE View Post
    I only see a small opening on each side of the metal shaft
    Oct 2012
    Louisville, KY
    1997 BMW Z3 1.9L 5MT
    BMW MOA 696, BMW CCA 1405
    Pelican Parts's Avatar
    Aug 2013
    Harbor City, CA
    '02 E39 Touring
    Hello - take a look at the link below to our site's DIY tech article on the procedure. Hope this helps you out!
    https://www.pelicanparts.com/BMW/tec...eplacement.htm
    888.280.7799 | 6am - 5pm PST
    Aug 2015
    Denver, CO
    1999 Z3M, 1999 2.8 Coupe
    I just pop the entire vent out (there's a screw up top that comes out after you remove the HL knob's cap, nut and stalk)...switch is simple to replace at that point. The vent is a bit tight, but it comes out just fine.
    Can see one of the switch tabs below...I had the switch exposed to replace the little bulb and to tap a dimmer wire (the big grey one if anyone needs to know) for a gauge install.
    Quote Originally Posted by Pelican Parts View Post
    Absolutely unnecessary to remove the lower panels (photos 1-5).
    Nathan in Denver
    Aug 2015
    Denver, CO
    Quote Originally Posted by Vintage42 View Post
    I never thought about removing the defroster vent, but that's not a bad idea. It comes out just fine without doing that, but that'd let you get a bit more leverage on it.
    Nathan in Denver
    birmingham,al
    I chose to pop out the entire front vent so I could see those dang tabs....what a PITA. Anyway, it's done....had to purchase a thin blade screwdriver. Thanks to everyone for your advice/help.
  1. Removing Z3 dimmer switch...
    By stjobs in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 08-28-2007, 09:11 AM
  2. Fog Light Switch and DDE
    By Jesper in forum 1991 - 1999 (E36)
    Last Post: 05-15-2004, 07:16 AM
  3. WTB: Interior Fog light switch and fog light relay
    By kt1 in forum BMW Parts Wanted
    Last Post: 03-04-2004, 01:06 AM
  4. Removing the ignition switch tumbler??
    By BMWFAN in forum 1991 - 1999 (E36)
    Last Post: 11-30-2003, 08:31 PM
  5. Brake Light Switch
    By Kramer in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 07-25-2003, 10:15 PM
