Hallo everyone. This weekend I am about to update/flash my SGM/SIM module on my E65 2008. However after a lot of reading I finally feel confident to make the procedure. I am familiar with all the programs needed. I just have some questions for you :
1. I will make the procedure to my existing module because of the 93F9 internal capacitor voltage too low. Do I still need to restart the system time in the module(s) ?
2. Also does it matter if I have the latest SP daten for my car as it is 2008, or I can also use a bit older like (50 to 59)?
All opinions are really appreciated.
Thank you very much.
Hi, Have you replaced the capacitors in the SGM module that are causing the 93F9 code. I,ve been trying to find some 8200uF 63v 105c deg. 35mm x 35mm capacitors with no luck, please let us know if the reflash works.
