Results 1 to 9 of 9
Thread: Diffsonline 420G reviews?
    Mar 2011
    PNW
    LS E46
    Question Diffsonline 420G reviews?
    My 3rd gear synchro is just about toast, lots of high RPM board shifting has taken its toll. I've been contemplating a dog box - but there's not much for options if I want overdrive (which I most certainly do). Seeing as I've never actually felt what a brand new 420G even feels like, I could only imagine it's amazing, so maybe the Diffsonline 420G is all that I need. Does anyone run one?
    A house
    '86 325e, '14 VW EPA
    Not what you're asking but a cool option to consider would be a dog box T56 from GForce - they will make the first 4 gears dog engagement and 5/6 synchronized, so you kinda get the best of both worlds. And quicktime now makes a bellhousing to fit a T56 to an M50.
    https://www.jegs.com/p/Quick-Time-Be...16244/10002/-1
    Mar 2012
    Renton, Wa
    98 m3
    We also are offering gs6-53 swaps.
    1989 535i - sold
    1999 M3 Tiag/Dove - sold
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    420G is rated at only 420 NM (310 lbs) torque while a GS6-53 is rated at 530 NM (390 lbs) and BMW put it behind the turbo V8 F10 M5 that made 502 lbs torque so it is somewhat officially under rated. The GS6-53 is the stronger and better shifting trans. I signed up for one if Vollosso’s conversion kits.
    But a trans like the T56 Magnum is even heavier duty — rated at 700 lbs. It would be a more expensive conversion since you can’t find used Magnums and new ones are $3200 plus $900 for the bell housing and you will still need a flywheel, clutch, driveshaft, support brace, and probably a short diff (3.62 - 3.85?) due to the trans gear ratios.
    Mar 2011
    PNW
    LS E46
    I have the S6-53 in my E92 - I don't like it. It does not like high-rpm shifts at all. I've yet to meet a ZF trans that I've liked. The G-Force T56 is actually the only other option I am seriously considering because this is behind an LS already, but I never really hear anything good about a T56 - it's just what everyone uses because there really isn't any other option. Besides, with a new flywheel, clutch, slave, driveshaft etc etc, the G-Force box is gonna be more than the 420G.
    Mar 2012
    Renton, Wa
    98 m3
    Quote Originally Posted by Liquidity View Post
    Reduce clutch inertia and remove that Cdv. Maybe you’ll like it more?
    1989 535i - sold
    Jun 2005
    New England
    I have the GS6-53 in my 08 E90 M3 and like it and it shifts fine at 8500 rpm. No clutch delay valve on the E9x M3 and it has a factory twin disk clutch. 335i may be different. If money and time were no object, I would lean towards the Magnum conversion but probably not a GForce dog box one for my street use.
    Mar 2011
    PNW
    LS E46
    So no one has the diffsonline 420g?
    Jun 2005
    New England
    $5000 is expensive for a trans, so it is probably a slow seller and none of the few buyers are active here right now. Rumor is it’s the same one Turner sells, but I don’t think there are any reviews there, either:
    https://www.turnermotorsport.com/p-3...46-m3/?pdk=AQE
    It has to be better than a 12-17 year old stock one. There was a guy selling rebuilt cyro treated ZF320 here. One guy spent the money to buy it and blew it up on his first event, but he had a very high power turbo E36M3. Hopefully this 420G rebuild addresses whatever issues you are having with 420Gs. Call Dan to ask.
  1. E39 540i or M5 Getrag 420G output flange
    By foofopps in forum BMW Parts Wanted
    Last Post: 05-31-2018, 11:31 PM
  2. Magazine Reviews of E36 M3
    By 8675309 in forum 1992 - 1999 M3 (E36)
    Last Post: 12-18-2003, 06:57 PM
  3. PC/Laptop Reviews
    By hermunn123 in forum Off-Topic
    Last Post: 07-01-2003, 12:23 AM
  4. E36 mag reviews?
    By berserkr in forum 1992 - 1999 M3 (E36)
    Last Post: 10-03-2002, 07:26 PM
