Results 1 to 12 of 12
Thread: Uneven height of z3 rear corners
    Dec 2011
    Riga, Latvia
    2x 1997 BMW Z3 2.8
    Noticed on my z3 roadster 2.8 that space between tire and rear quarter is uneven on left and right side - car sits around 1" higher on left side even with fuel tank almost empty. Also tire wear on right side is a bit bigger.
    Car has Powerflex poly bushes everywhere in suspension/subframe, new Bilsteins B8 shocks installed last year with less than 1000 miles on them since with lowering ACS spings. It also has spare tire fitted, heavy battery (more than 20kg or 44 lbs) and SuperSprint catless sport exhaust installed.
    Wondering if uneven height might be just because of weight differences for stock exhaust and SuperSprint exhaust. Anyone experienced the same after exhaust upgrade?
    If that's the case, probably getting more lightweight battery or getting rid of spare tire should help, right?
    P.S. Don't look at signature pic, that's not the case (that's some drag race run on stock shocks), but looks a bit similar actually
    Drivers side sits higher
    Dec 2011
    Riga, Latvia
    2x 1997 BMW Z3 2.8
    Quote Originally Posted by BimmerBreaker View Post
    Yes, if that was the question.
    Aug 2015
    Denver, CO
    1999 Z3M, 1999 2.8 Coupe
    Your butt in the driver's seat should even things out, but that might be hard to remeasure when you're sitting there.
    BB's response was to tell you that it was by design for the driver's side to sit slightly higher so the car is more balanced with you in it.
    Would you rather the car sat level parked then was lower on the driver's side while you were driving?
    Nathan in Denver
    No it was a statement, its designed that way so when a single driver sits in it the car sits evenly, since most people drive with a single driver
    Aug 2014
    Northern CA
    1999 M Roadster
    I didn't know this about the vehicle, neat fact and attention to detail.
    Austin, TX
    2001 M Roadster
    My question, I guess, through what mechanism is that height difference achieved? Springs? Some thing else more substantial? People who run aftermarket suspensions, is the difference still there?
    Mar 2003
    somers,ny
    double driver mode has its own set of issues
    Dec 2011
    Riga, Latvia
    2x 1997 BMW Z3 2.8
    Thanks for replays. Need to measure the difference with me at drivers seat. Probably will need to consume more food to adjust the car height properly.
    Aug 2012
    Kansas
    2000 m roadster 2010 x3
    Could a rear spring be bound ?
    Jan 2015
    Georgia
    2004 M3
    Quote Originally Posted by z3forlife View Post
    Or a broken/missing spring pad
    Dec 2011
    Riga, Latvia
    2x 1997 BMW Z3 2.8
    Will check, but I highly doubt there are any issues with springs or pads. Passed a MOT just a couple days ago, they should notice things like that.
  1. GC rear height adjuster question
    By BlueMaxx9 in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 03-17-2004, 02:44 PM
  2. Read ride height uneven after Koni install, do I...
    By DallasM3 in forum 1992 - 1999 M3 (E36)
    Last Post: 08-14-2003, 07:40 PM
  3. Uneven Rear Tire Wear = Problem??
    By 325isBPW in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 07-03-2003, 09:17 PM
  4. Rear ride height?
    By NLR in forum 1992 - 1999 M3 (E36)
    Last Post: 05-22-2003, 03:41 PM
  5. FS: H&R rear ride height adjusters
    By jvit27 in forum BMW Parts For Sale
    Last Post: 06-22-2001, 10:21 AM
