Results 1 to 3 of 3
Thread: Tracking an oil leak on a '07 335i.......
    Mar 2004
    Tyler, Tx
    '01 740i Sp, '07 335i
    A little history first - this is a car that I bought about a month ago has 127K miles. SO far I have replaced the thermostat, water pump and most of the coolant hoses. I also replaced the oil filter mount gaskets and the cooler connection gaskets. these were leaking. I also replaced the valve cover gasket but don't think it was leaking - at least no oil in plug wells and both side of the gasket were dry on the mating surfaces. I also installed a catch can while doing this.... I have only run the car maybe 5 minutes since all of this but there is still oil forming on the bell housing, running down and dripping on the floor. I was able to speak with the shop this morning in NJ that replaced the turbos last year - 4 K miles ago. He was super and the owner of the shop that did the work. He is an ex-BMW tech that seemed pretty sharp. He said he remembered the car and the job - he replaced the turbos with BMW updated turbos - but only replaced the "O" rings on the oil feed lines - PO was trying to save some money at that point.. Bill was over $6K for what they did.
    I have a Bore scope/camera that I have tried to look up in that area to find leak origin - no luck. The oil pan is also wet so I guess I will do that next as well. FYI: The leaks start higher than rear or front main seals...
    Looking for answers from anyone that has chased these leaks down....
    http://i293.photobucket.com/albums/mm71/krallopian/darthSigTest2_zpsn6zkw5id.jpg[/URL][URL="http://www.facebook.com/pages/DFW7-Dallas-Fort-Worth-BMW-7-Series-Club/300942239566"]DFW7 on Facebook/URL]
    "The Last Great e38" 2001 i Sport - Born'd on date 1/01 Cosmos/Grey - 32.8K miles - 2 1/2 " Custom Exhaust, Center “X”over , Modified OEM rear bumper, M5 style trunk spoiler, M6 OEM wheels, M3 Steering wheel with working paddle shift & CF trim, Bi-Xenon upgrade, 13mm Rear sway bar added, SS brake lines and bronze bushings, Cross drilled rotors and painted calipers, Akebono pads, Zionsville aluminum radiator & exp. tank with electric fan, Sprint Booster, BluTooth conversion, MKIV Nav., Custom wood cupholder, DUDMD Tune, Orien V2.5 LED Angel Eyes, Evans waterless. Recently added grey faced //M5 Cluster - all gauges functioning. Changed the grey carpet to black and topped off with GG Bailey front/rear mats[/SIZE]
    Mar 2004
    Tyler, Tx
    Up date - I found the oil pan to be leaking quite badly so I guess that will be next. Then when draining the oil I discovered that it had too much oil - don't really know how much to much as it went into my drain catch can. I know it drained too long for 6 qts thio....no damn dip stick, hate that!
    Mar 2004
    Tyler, Tx
    The pan is finished and car is back together....I don't ever want to do that job again. After dropping the front sub frame to accomplish this job I am here to say it is a BITCH. After purchasing this car just over a month ago I have now driven it about 200 feet and I have replaced the water pump,multiple hoses, thermostat, valve cover gasket, power steering res and two hoses and lastly the oil pan gasket.......I am thru for a while.
  1. 2008 335i Coupe - brakes upgrade
    By Kerry Newman in forum 2006 - 2012 (E90, E91, E92, E93)
    Last Post: 07-28-2018, 06:03 PM
  2. 2013 F30 335i Estoril MSport ~33.5kmi (Northern VA/DMV) $28,250 obo
    By F30Gators in forum BMW Cars For Sale / Wanted
    Last Post: 06-17-2018, 01:26 PM
  3. FS: 2009 E92 335i X-Drive 6MT - Monaco Blue - 69k Miles!
    By rossim22 in forum BMW Cars For Sale / Wanted
    Last Post: 05-24-2018, 04:09 PM
  4. up to 15% Off the 335i/335is N54 Lightweight Performance Flywheel
    By TurnerMS in forum 2006 - 2012 (E90, E91, E92, E93)
    Last Post: 05-18-2018, 11:52 AM
  5. Oil leak wasn't really a leak...VANOS change...
    By Ralbo147 in forum 1999 - 2006 (E46)
    Last Post: 01-05-2004, 10:37 PM
