Results 1 to 12 of 12
Thread: Oil leak...
    Jun 2016
    Winter Park
    1999 BMW 528i E39
    Oil leak...
    Hey
    So on my 99 528i, I did the OFH gasket a couple months ago and just did the VANOS oil line a few days ago. I replaced the CCV, oil separator, and everything a year ago. However recently there has been this oil leak that has me bummed out. It's leaking on the drivers side.... so makes me think it has to do with something under the manifold.... what other common leaks are there. The car is around 105k miles.
    T
    Jun 2013
    Boston, MA
    99 528i/5, 05 ZHP conv
    That's near the front of the engine. There isn't much else in that area that leaks oil. How fresh is the valve cover gasket ? It does'nt usually leak at that location. Should you double check all CCV hose connections? Did you use new washers on both ends of the new vanos line? Check the vanos line bolts?
    Jun 2016
    Winter Park
    1999 BMW 528i E39
    Valve cover gasket never was done. Could be that. I did not tighten the Banjo bolt very tight as many forums warned against over-tightening it.
    One other thing was when removing the original Banjo bolts, the two washers outer diameter sizes were different.... but when I went to the dealership to buy new washers, they said that the two washers on either sides are the same.....
    I'll take a pic when I get home.
    Oct 2017
    Chicago, IL, USA
    2002 BMW 530i
    How about the oil filter housing gasket?
    That is a common failure over time where oil starts leaking near the location of your pic.
    Sep 2011
    Milton, WV
    2002 BMW 530i Sport
    His original post says he did the oil filter housing gasket.
    If all your previous work is up to snuff could be the oil pan gasket.
    Jun 2013
    Boston, MA
    If you think the valve cover gasket is original, or it’s age is unknown, you should definitely replace it. Not sure that is the link here. Make sure those banjo bolts are snug but don’t overtighten them. There should be washers in either side of the “banjo”. I always assumed they were the same.
    Aug 2016
    Virginia,USA
    528i, 525iT, M5
    I think you have the evil oil pressure seal plug leak that is located on the back side of the oil filter housing. You can confirm with a bore scope or a mirror. If it is the plug there are a few hacks or you buy the entire housing. Good luck.
    Current Garage Highlights
    2003 525iT TiSilver
    2002 M5 TiSilver
    Former Garage Highlights
    2005 X5 4.8is
    2004 325iTs (2x)
    1973 Pantera L
    1969 Road Runner 383
    Jun 2016
    Winter Park
    1999 BMW 528i E39
    Hey so I ended up figuring out what it was. It seemed to be the new crush washer that I installed.....
    Here is what I bought
    And 4x new OEM GENUINE crush washers at the dealership.
    Might need to go with genuine on this one.... I think it may be because of the aftermarket part.... it was five stars though so I don't understand......
    Sonoma Whine Country
    E12, E12, E36, E39
    URO parts do not have a good reputation, although my experiences haven't been bad. Crush washers I'm almost embarrassed to say I almost always reuse without leaks. It having two different size crush washers when you got in there may be a key though.
    98 328is
    02 525ita
    80 528i
    81 528ia
    and decades of owning and driving BMWs
    Jun 2013
    Boston, MA
    Quote Originally Posted by tek.to View Post
    Here is what I bought...
    Not clear what you mean....so do you think it's the washers or the line itself?
    Jun 2016
    Winter Park
    1999 BMW 528i E39
    Still not sure since it was an aftermarket part. I already reordered the same line on FCP with new washers, etc.
    Los Gatos CA
    1987 325is, e34, Z3, e39
    The proper washers are tin plated copper. They need to deform slightly in order to seal. Use a torque wrench to tighten the banjo bolt to get the proper deformation.
    Inspect the surface of the end fitting and banjo bolt when you remove the hose. If I recall, Uro uses black painted fittings. The sealing surfaces may have a paint drips, rather than being flat and smooth.
  1. 840 Top End leak
    By Jolo3361 in forum 8 Series (E31)
    Last Post: 05-19-2018, 01:48 PM
  2. Oil leak....
    By RJ 325is in forum 1991 - 1999 (E36)
    Last Post: 02-12-2004, 10:49 AM
  3. Really bad oil leak
    By dubumb in forum 1988 - 1996 (E34)
    Last Post: 02-01-2004, 12:19 AM
  4. Oil leak wasn't really a leak...VANOS change...
    By Ralbo147 in forum 1999 - 2006 (E46)
    Last Post: 01-05-2004, 10:37 PM
  5. Oil Leak
    By Stan Gable in forum 1992 - 1999 M3 (E36)
    Last Post: 10-03-2003, 07:59 PM
