Results 1 to 9 of 9
Thread: Help with AC Compressor
    Aug 2016
    Mclean, VA
    1992 850i, 2015 M5
    In need of some expert advice here. The compressor seams to be losing power and shutting down randomly. After disconnecting and reconnecting it begins to work again until the car is turned off and then wont reengage. Time for a new compressor or just a control unit thing? Any thoughts would be appreciated.
    Feb 2016
    Brooklyn, NY
    1995 840Ci, 2013 X5
    The first thing is to check the refrigerant charge. Your symptoms correspond to an overpressure safety shutdown usually caused by low refrigerant.
    Brett
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    Watch the auxiliary fan - if that is running so should the compressor - aux fan not running = compressor not running.
    My BMW Repair YouTube Channel
    Aug 2016
    Mclean, VA
    1992 850i, 2015 M5
    Quote Originally Posted by ltbrett View Post
    Brett
    Thanks, refrigerant was fully charged during testing.
    Aug 2016
    Mclean, VA
    1992 850i, 2015 M5
    Aux fan working as it should. Going to check to make sure there is no belt slippage next but oddly, compressor works fine when cold but shuts down after it warms up...5-10 minutes after running.
    Feb 2016
    Brooklyn, NY
    1995 840Ci, 2013 X5
    What you are describing still sounds to me like a safety shutdown. You need to monitor both high and low side pressures from a cold start to shutdown to really see what is up.
    Brett
    Aug 2016
    Mclean, VA
    1992 850i, 2015 M5
    Brett
    That's what I thought. Thanks!
    Jun 2010
    Hyperworld
    '97 840CI
    ...You need to monitor both high and low side pressures...
    I must inject a nuance which is that operations don't care what a technician gauge set says the pressure is, but rather what the controller box thinks it is.
    So for this troubleshoot the seasoned technician will be looking primarily at the output of the pressure switches with a 2nd opinion or reference measurement coming in from the gauge set.
    IOW's sensing could be funky.
    Probably not related to this BMW case, but some compressors, like on my MBZ, have a compressor speed sensor, to check for slip and overspeed.
    In such a case I would be checking for (electrical) noise or drop out.
    Also wondering if any of this sensing or faults would show up on scan codes.
    Aug 2016
    Mclean, VA
    1992 850i, 2015 M5
    Good stuff...makes total sense. Unfortunately nothing on the scan.
    Quote Originally Posted by Hyper View Post
  1. Air Compressor
    By Kevlar in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 08-01-2003, 06:55 PM
  2. a/c compressor ?
    By Bremsen in forum 1991 - 1999 (E36)
    Last Post: 08-01-2003, 10:55 AM
  3. E23 A/C Compressor
    By rodgerste in forum 1995 - 2001 (E38)
    Last Post: 07-22-2003, 09:10 AM
  4. WTB e36 M3 A/C Compressor
    By ///Maestro in forum BMW Parts Wanted
    Last Post: 05-17-2003, 12:27 PM
  5. WTB:95 M3 AC compressor
    By BMWM3some in forum BMW Parts Wanted
    Last Post: 10-22-2002, 04:53 AM
