I have a 750i with N62 engine in which I did a valve stem seal replacement using the AGA tool. After everything is back together it runs terrible. The scanner reads several codes such as CAM sensor and misfire on cylinders 1-2-3-4. I replaced the CAM sensors same code and problem. Then did a compression test, all cylinders on the troubled side have zero compression. This is to my surprise because the car ran fine prior to doing the job, and I also hand turned the engine prior to finishing the job just in case, and there was no problems. Could there be a broken wire, bad IVM computer, the timing / Cam “slipped”, or something else? I am out of ideas other than bent valves, but the car ran fine prior it just smoked bad.
I have posted that I ran into the same issue. Wondering if you managed to fix it.
Thanks,
Ghassan...
