Results 1 to 10 of 10
Thread: Steering wheel control up and down and in and out stop working today
    Jan 2014
    Huntington Beach, Ca.
    Tesla, Hummer H2, 840Ci
    I check all the fuse and it all fine. Any help would be appreciate. Thanks
    Sent from my iPad using Tapatalk
    Apr 2013
    Seattle WA USA
    1991 BMW 850i
    Double check the fuses in the trunk?
    Orange County, CA
    840Ci|725tds|Alpina B7
    Only thing that fixed mine was swapping the steering column module behind the MID
    Mar 2006
    Harrisburg, PA, USA
    x5, 640i, 850Ci, 850CSi
    Quote Originally Posted by olinjohnston View Post
    Sometimes recalibrating the module works. You need to pull the fuse for 15 minutes, then after you reinstall it, move the wheel full up and hold for 15 secs, full down and hold, full in and hold, then full out and hold.
    Of course, if it isn't working at all and the fuse is good, then as olin said, it must be the module -- part number 32-31-1-160-011. I've found them on ebay (sometimes checking german ebay as well). It's located in the center of the dash behind the middle vents, but it's better to remove it by removing the MID display, rather than risk breaking the fragile vent unit.
    Mike Barrett
    Mike Barrett
    94 850CSi, Hellrot over silbergrau dunkel/silbergrau hell
    96 850Ci, Oxfordgrun over silbergrau hell
    Jan 2014
    Thanks For all the input. Will try it this weekend. Which fuse Mike ? F18 in the engine compartment or F40 in the trunk? I am hoping it is not the Steering module. Thanks
    Apr 2013
    Seattle WA USA
    1991 BMW 850i
    IIRC the trunk one.
    Jan 2014
    I just tried both front and rear fuse and that didn’t work. Going to deal with it this weekend on the steering wheel control module next. Thanks
    San Ramon, CA
    850Ci, M5, Model-S P85D
    Quote Originally Posted by tran2tran View Post
    This is certainly becoming more common given the age of the electronics modules.
    Typically, it requires replacing $5.00 worth of electrolytic capacitors to fix the unit.
    Refer to the post below. Note if you replace the Steering column control module (rather than repair yours) it will need to re-calibrated with a DIS.
    https://www.bimmerforums.com/forum/s...umn+controller
    Jan 2014
    Quote Originally Posted by m6bigdog View Post
    Thanks for the info
    Jan 2014
    Well after disconnect the battery on both side and left it off for a week and during that time i recharged both battery and reconnect it this morning and did the calibration and its all working now. Most likely the battery issue so going to see if the battery will hold the charge this week if not i will be out buying two new battery. Planning to head out to the HB Concourse this weekend to pick the brain of the Socal8 Guru.
    Quote Originally Posted by mbarrett635 View Post
    Mike Barrett
  1. Replies: 16
    Last Post: 03-11-2013, 08:22 PM
  2. HELP! cruise control not working-speed sensor not working
    By BiMmEr JoN in forum 1991 - 1999 (E36)
    Last Post: 01-28-2004, 06:43 PM
  3. Why did my Sig pic stop working?
    By gato in forum Off-Topic
    Last Post: 09-19-2003, 03:20 AM
  4. Replies: 6
    Last Post: 03-20-2003, 07:54 AM
  5. Replies: 0
    Last Post: 02-04-2002, 03:07 AM
