Results 1 to 6 of 6
Thread: Lug Bolts
    Oct 2016
    Shoreview MN
    Had a 1991 BMW 850
    Lug Bolts
    Pulled the fronts off my 1991 850 and found 9 Lug Bolt of three different lengths. The Shortest of the three have about six threads of engagement. They are all going into the recycling bin.
    Standard BMW E31 rims, no spacers
    What is the standard size? Pelicanparts lists M12 x 1.5 in the following lengths 22, 24, 28, 29, 30, 35, 38, 43, etc etc
    I cant figure out how to post a picture
    Wadsworth, Ohio
    BMW
    Stock wheel bolts are 26mm conical seat (LINK).
    -James
    Oct 2016
    Shoreview MN
    Had a 1991 BMW 850
    Thanks I am going to measure what I have (double check) and order some tonight
    Dec 2007
    Dallas, TX
    '93 850Ci- Daily Driver
    Rule of thumb: the thread “engagement” of the bolt should be as deep as the width of the bolt itself, i.e., if the bolt is 12mm in diameter, you want at least 12mm into the hub.
    '93 850Ci - Mineralweiß Metallic
    2001 740iL - Titansilber
    ALPINA B7 -Alpinweiß III
    Oct 2016
    Shoreview MN
    Had a 1991 BMW 850
    Threads
    Quote Originally Posted by TxGR8White View Post
    I looked at the 26MM ones again and they exceed the rule of thumb. What I thought they were engaging to was wrong. Plus all of the other mismatched ones threw me off
    Now to finish up on my Valve Body in the Transmission
    Dec 2007
    Dallas, TX
    Be careful with “longer” bolts as they will interfere with the emergency brake components in the rear hubs.
  1. ARP S50/S52 Rod Bolts
    By RRdawho? in forum Group Purchases & Supporting Vendor Specials presented by eBay
    Last Post: 03-15-2004, 03:55 AM
  2. Do I need new LUG BOLTS?
    By JedzE36/5 in forum Wheels and Tires
    Last Post: 07-10-2003, 06:00 PM
  3. HELP! rotor hex bolts won't come out!
    By shark328 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 06-09-2003, 01:33 AM
  4. Lug bolts
    By Rel44 M3 in forum 1992 - 1999 M3 (E36)
    Last Post: 06-10-2002, 11:31 AM
  5. why does BMW use lug bolts?
    By BJO in forum 1992 - 1999 M3 (E36)
    Last Post: 08-23-2001, 01:15 AM
