Results 1 to 7 of 7
Thread: Manual 1994 325i gear with exclamation mark inside of it light
    May 2018
    Colorado
    1994 325i/ 1997 318ti
    Hi there I have a Manual 1994 325i and there is a light on the dash that is a gear with a exclamation mark inside of it, I've read this means the trans is faulty but everyone also says there having problems getting there car into gear, and there cars are all automatic. My car doesn't have any problems with the transmission, shifts smoothly into every gear, and downshifts. Could it be a bad sensor? Or am I low on trans fluid?
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    post in the regular E36 forum, thread moved
    Jan 2018
    Earth
    Quote Originally Posted by benbejammin View Post
    Somewhere along the way, a previous owner swapped your instrument cluster with one from an automatic. You can remove the bulb from the back of the cluster and you're good to go.
    May 2012
    Central Wisconsin
    '94 325i, '93 325is
    Or the car used to be an automatic and was manual swapped. Either way the light means nothing. Remove it from the cluster.
    '94 325i Sedan, Arctic Gray: UUC LTW FW, EVO 3 and DSSR, +.020 Maxsil pistons, ASC delete, Eibach shocks/springs, 16" contour reps 238k
    '93 325is Coupe, Schwarz, work beater 299k
    '89 325i Vert, Alpine White: 5spd swapped. Sold
    '04 Toyota Sienna XLE Limited AWD, In progress swapping to M50/G250, http://www.wibimmers.com/board/index...nna-25i-build/
    '05 Volvo V70 R, 6mt, mostly stock, kid hauler 200k Sold
    '85 Toyota LandCruiser: Lifted, gas hog. 205k
    Oct 2016
    Austria
    e36 323i, M3 3.2
    do you have an automatic or a manual?
    May 2012
    Central Wisconsin
    '94 325i, '93 325is
    First sentence of original post "Hi there I have a Manual 1994 325i"
    Jul 2010
    Murrieta, CA
    '94 325iC, '08 328i, E93
    That light is invalid for a manual transmission. It means there is an issue with the transmission controller or the transmission electronics, but your car has no transmission controller or electronics.
  1. Transmission light Gears with exclamation point
    By aarnoldupenn in forum 1999 - 2006 (E46)
    Last Post: 07-01-2022, 05:17 PM
  2. FS: 1994 BMW 325i
    By fasterbmw in forum BMW Cars For Sale / Wanted
    Last Post: 08-03-2003, 07:50 PM
  3. 1994 325is manual trans swap
    By M34life in forum 1991 - 1999 (E36)
    Last Post: 05-07-2003, 03:36 PM
  4. 3m Swirl mark remover for light or dark?
    By El Nino in forum Car Detailing and Show & Shine Prep sponsored by Autogeek.net
    Last Post: 03-11-2003, 11:15 PM
  5. How much for 1994 325i, 88k?
    By Andrew9682 in forum 1991 - 1999 (E36)
    Last Post: 05-07-2002, 01:25 AM
