Results 1 to 6 of 6
Thread: New to E36's, Cam Position Sensor Code = DME failure?
    May 2018
    Midwest, USA
    1996 BMW 328is
    A few days ago I picked up a '96 328is (my first BMW) from a somewhat shady guy. The CEL is on for the cam position sensor, but I have reason to believe that he replaced the sensor but couldn't get rid of the CEL to pass inspection, leading to him selling me the car. I read on this thread that this can be a symptom of a fried DME. I found the original cam sensor in the trunk, and the wire insulation was blown up just like the guy's in that thread.
    So I guess I need a new DME, but I don't know anything about them or how much to pay for one. If anyone has some tips or advice, I would greatly appreciate it.
    The cowl drains are clogged too, so maybe some water amplified the issue.
    Thanks in advance
    Mar 2013
    Upstate NY
    M3
    For these cars, specifically the cam sensor... it HAS to be oem, I cut corners and use OE replacements all the time but for that sensor Id recomend using oem. (Still may not fix your problem)
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    DME's seldom go defective, but of course cannot be excluded, I would first test all the other sensors.
    Oct 2003
    Seattle
    99 M3
    IF it is the ECU, which is questionable, you will need a shop with a GT1 or the Dealership to align the ECU to the EWS.
    https://www.turnermotorsport.com/t-faq-ews
    Or get an EWS delete ECU update.
    Oct 2016
    Tenerife, Spain
    1997 BMW E36 323i
    Quote Originally Posted by bluptgm3 View Post
    Or you can use your own laptop and get an USB to OBD2 interface (and probably the BMW 20-pin diagnostics plug to OBD2 convertor) and a very small computer program to sync the EWS (no need to install INPA and all, just a very small program). I have it on my laptop, but it can also be downloaded for free. I can look it up if you want. Update: Already found it: https://www.bimmerforums.com/forum/s...0-vagcom-cable . I've used it before and it works great.. Couldn't get it to work with the official BMW software, but this little program did it in a few seconds.
    But I also doubt it would be the DME (but it is possible, especially with the E36's not water-tight DME location; with the E32/E34 it's a lot better in its own sealed compartment).. Sensor and wires would be first suspects. Perhaps good idea to connect a laptop with INPA software and check all live sensor values and read all error messages.. That often helps a lot to find the cause.
    Apr 2015
    Tennessee
    1998 BMW 328i
    Trust nothing. Id change the sensor
  1. Cam Position Sensor
    By ae86_16v in forum 1991 - 1999 (E36)
    Last Post: 03-11-2004, 10:53 AM
  2. Replies: 0
    Last Post: 11-23-2003, 11:21 AM
  3. Recurring Throttle position sensor code...help...
    By Mpowered02 in forum 1992 - 1999 M3 (E36)
    Last Post: 09-12-2003, 05:17 PM
  4. Camshaft Position Sensor
    By bjchacha in forum 1991 - 1999 (E36)
    Last Post: 03-28-2003, 01:06 AM
  5. throttle position sensor
    By mazen in forum 1991 - 1999 (E36)
    Last Post: 09-02-2001, 06:43 PM
