Results 1 to 6 of 6
Thread: 1995 M3 misfire, 1226 code
    Mar 2013
    lafayette, california
    1998 bmw 328is
    Help guys. I've recently run into a problem with my 95' M3 where the car seems like it's misfiring, check engine light on, terrible acceleration and bad idle. Did the stomp test and pulled the code 1226 (knock sensor #2). Could this problem be the knock sensor or something totally different?
    Sent from my SM-G930P using Tapatalk
    Oct 2003
    Seattle
    99 M3
    How many heat cycles on knock sensors? They can crumble as they age.
    Conversely, get some contact cleaner and lubricant and clean the harness connection.
    Mar 2013
    1998 bmw 328is
    Quote Originally Posted by bluptgm3 View Post
    Heat cycles? I just ordered 2 knock sensors to replace #1 and #2. Could a faulty knock sensor really cause the car to be almost un drivable?
    Nov 2007
    Central IL
    E36
    When my 1226 code came on (every now and then) it was fine to drive. I did notice a bit better torque after I swapped them. (They are tough but do-able w/o removing the mani).
    It sounds like you have a different issue though, vacuum leak to start?
    BMW CCA Illini Chapter Vice President
    1995 M3
    - My Favorite DIY's and FAQ's
    Beaufort, SC
    81 C1, 89 ix, 04 M3
    Unplug your maf and see if it evens out.
    Then clean the maf with maf cleaner.
    Mar 2013
    1998 bmw 328is
    Quote Originally Posted by mossyoaks View Post
    Already cleaned it. Are you saying unplug it and let it run unplugged?
  1. knock sensor # 2 - 1226 code
    By craaaazzy in forum 1992 - 1999 M3 (E36)
    Last Post: 05-13-2003, 02:05 PM
  2. F2 Code - Misfire Cyl 5 ? Should I worry ?
    By JLee in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 04-21-2003, 01:14 AM
  3. Flash Code 1226 95 M3, knock sensor?
    By ///Arman in forum 1992 - 1999 M3 (E36)
    Last Post: 10-29-2002, 07:22 PM
  4. dme code 1226
    By BJO in forum 1992 - 1999 M3 (E36)
    Last Post: 10-16-2002, 10:00 PM
  5. Knock sensor check engine code 1226
    By ultim3 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 03-23-2002, 04:16 PM
