Results 1 to 7 of 7
Thread: Can I still run the engine w/no oil in the tranny?
    Sep 2010
    Berkeley, CA
    2001 750iL
    Hi everyone. I learned a costly mistake over the weekend. I used a harbor freight torque wrench to tighten the transmission oil pan. I had tested the wrench several times earlier and to my surprise it worked fine. So after going through the procedure listed here http://www.e38.org/zf-5hp30-service.html, (even using the neat little trick of if a bolt strips use an 11mm box wrench over the bolt. I only had two strip. I used a hammer and gently tapped the box wrench over the bolt), I was at the point of tightening the pan to 15lbs. Well I kept waiting for the wrench to click and before I knew it, I heard a crack instead and there went the aluminum pan. I know (sigh)...it was a rookie mistake. I ordered a new pan this morning from pelican parts along with new fill and drain washers.
    In the meantime, can I turn over the engine to keep the batteries from dying or will I screw of the tranny? Also since I clearly over tightened the pan, will I need a new gasket? (the one on there is new).
    Thanks for your input.
    Aug 2017
    Wayne,PA
    740iL (E38 '01)
    I wouldnt run the engine/tranny without oil, other than no lubrication it gets no cooling either. I'm sure you can cook it fast.
    My best investment was a digital CDI wrench, they are so much better than the mechanical ones. Costly tho, approx $300.
    Doubt the gasket is damaged by this tho.
    Sep 2010
    Berkeley, CA
    2001 750iL
    Thanks for your input. I'd rather be safe then sorry. I'll look into the wrench.
    Aug 2017
    Wayne,PA
    740iL (E38 '01)
    This my torque wrench: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    It's great cause you can use it for really small torque like 8Nm valve cover but also going up to 25-27Nm like oil pan drain plug etc.
    I only use a mechanical one above 27. Like my transmission drain plug is at 35Nm, not sure if same for 750.
    Dec 2017
    Rhode Island
    2000 750iL
    I would say you can but why bother? your battering isn't going to die in a week. If you're that concerned just pull the negative cables or invest in a battery charger.
    Oct 2007
    Boca Raton, Florida
    89'750iL,98'740iL,00'M5
    That battery should last more than a month if it's in good shape. Definitely won't die while waiting for a part. And also I agree with those above because the oil pump in the transmission will run while dry.
    Sent from my ONEPLUS A3000 using Tapatalk
    BMW 7er Website www.7er.com
    1989 BMW 735i Schwarz (sadly, sold) // 1989 BMW 750iL Cirrusblau Metallic // 1998 BMW 740iL Oxfordgrün Metallic // 2000 M5 Carbon Schwarz ///
    Sep 2010
    Berkeley, CA
    2001 750iL
    Thank you for all your replies and the info on the wrench.
  1. WTB m30 engine and tranny
    By X2theZ3 in forum 1988 - 1996 (E34)
    Last Post: 03-23-2004, 11:43 PM
  2. WTB 3.5L m30 engine and tranny
    By X2theZ3 in forum BMW Parts Wanted
    Last Post: 03-23-2004, 03:01 AM
  3. WTB: S62 engine/tranny
    By MrWingnut10mm in forum BMW Parts Wanted
    Last Post: 03-18-2004, 12:06 AM
  4. would the 98 - 00 tranny fit the s54 engine
    By NightKidz in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 02-12-2004, 10:42 PM
  5. what engine/tranny in the 2.8L Z3
    By M3Jokster in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 08-28-2002, 11:39 AM
