Hi I have a 01 740i that's not starting but cranking. Any suggestions why
Have you attempted any type of diagnostic scan?
Moved to E38 forum.
Could be the immobilizer.
EWS III module.
Get a BMW scan on it and see whats going on.
Present:
'96 750iL (Project)
'95 C1500 350 V8
'03 540i M Sport AT
'22 GMC Sierra 1500 DD
'92 Olds Toronado Trofeo (Project)
Past:
'93 325is (Parted)
'95 840Ci (Sold)
'86 735i (Parted)
'02 Z3 3.0i (Sold)
'09 328i (Leased)
'91 750iL (Parted)
'00 Z3 2.5i (Sold)
'86 944 NA AT (Sold)
'84 633 CSi (Sold)
'06 X3 3.0 (Sold)
'20 M2:Competition 6spd (Sold)
Do you have a Check Engine Light on? It could be a number of things from the crank sensor to a dead fuel pump.
Here's my story for some lite reading,
https://www.bimmerforums.com/forum/s...Solved-for-now
Happened about four days ago.
01' 750il Chromeline
95 M3 LS swapped
07 M5 Manual
06' M5, Spartan wheels and a 507hp V10
00' 740il Dinan, CAI, Romulus exhaust, Stage 5 engine and transmission tune, 750 brakes, camber plates, strut tower brace. Sold
00' 323i wagon for daughter
03' 525i wagon for the wife, sold
98' 740i for the daughter, wrecked
92' 525i with over 200k, wrecked
02' R1200 CLC, hit by a bus and broken in half. That one made the news!
It's like herpes there is no cure but if treated properly you can live with it for the rest of your life
Yes no codes coming up but check engine light is showing. And a triangle and a circle around it ??
Sent from my Z982 using Tapatalk
That should have nothing to do with your no-start issue.
A scan for BMW codes is needed to reveal why the CEL is on.
I know so what could it be
You need to do some basic testing:
Check for sparks by removing a coil-over-plug unit, fitting a spare plug in it, reconnect the loom and rest the plug on a metal surface of the engine
Get someone to crank the engine - do you get sparks?
My BMW Repair YouTube Channel
I'll have to try that in the morning. Really a coil out and try to turn in over ?
Yes, the suggestion from Timm is really a very simple way to verify spark.
Follow whatever testing procedure Timm recommends, he knows these vehicles very well.
He is a resident expert here, if you haven't figured that out by now.
Visit his website using the link, you will be amazed!
+1
95 M3 LS swapped
07 M5 Manual
