Results 1 to 14 of 14
Thread: Battery issue - battery's good, won't start unless jumper pack connected
    Jun 2016
    Saukville, WI, USA
    1997 BMW 328i (convertib
    '97 328i (convertible).
    Brand new battery (actually replaced a brand new battery because we thought it was bad but that obviously wasn't the issue). Tested it and it's in peak condition.
    But the car won't start. Trunk lights, dash lights all come on when they should, but turning the key just gives me a whir and a click or two. If I hook it up to a jumper pack, it starts beautifully. Let it run for however long I want, doesn't matter. Turn it off and try to turn it back on again and nothing (or just a whir & click). Also the jumper pack is able to do this over and over and over again without needing to be recharged.
    Ideas for where to start to track this problem down?
    Nov 2007
    Central IL
    E36
    Loose/poor battery terminal connections. Clean them, re-tighten your cables.
    BMW CCA Illini Chapter Vice President
    1995 M3
    - My Favorite DIY's and FAQ's
    Jun 2010
    NY
    1997 328i
    If that doesn't do the trick, there may be a loose connection on one of the terminals at the jump box. If none of that works then the jump box may be cracked.
    Jun 2016
    Saukville, WI, USA
    Thanks! I'll get looking at those two things.
    Oct 2012
    washington, dc
    96 E36 Vert 03 E39 M5
    check your ground points.
    also inspect cables
    http://www.bmwmregistry.com/detail.php?id=13792
    * E39 M5 SterlingGray -RIP 11/2018
    * E36 328 vert Schwarz - ~TurboProject underway
    * E90 335i Sedan MonocoBlau - Daily ToddlerTaxi
    Apr 2015
    Tennessee
    1998 BMW 328i
    Check the ground strap that runs to the motor mount arm. Connect a jumper cable from the lift point on the vanos to a strut tower bolt. If it starts then your engine ground is bad
    Oct 2012
    washington, dc
    Shhh!!! The point is for him to check them all!
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    May 2012
    Central Wisconsin
    '94 325i, '93 325is
    Not the fusible link if it runs and starts sometimes. It sounds like a loose connection/ bad ground on a large power cable.
    '94 325i Sedan, Arctic Gray: UUC LTW FW, EVO 3 and DSSR, +.020 Maxsil pistons, ASC delete, Eibach shocks/springs, 16" contour reps 238k
    '93 325is Coupe, Schwarz, work beater 299k
    '89 325i Vert, Alpine White: 5spd swapped. Sold
    '04 Toyota Sienna XLE Limited AWD, In progress swapping to M50/G250, http://www.wibimmers.com/board/index...nna-25i-build/
    '05 Volvo V70 R, 6mt, mostly stock, kid hauler 200k Sold
    '85 Toyota LandCruiser: Lifted, gas hog. 205k
    Jan 2005
    Japan
    yes, it can also be the fusible link if it runs and starts sometimes, then the fusible link has a haircrack and sometimes works and sometimes not. This is not internet experience, my own experience , car was starting sometimes, sometimes dead http://www.bimmerboard.com/members/s...ible_E32_1.jpg
    But of course it can also be a loose connection/bad ground.
    Aug 2009
    sunnyvale CA
    325is
    Are you using the battery post in the trunk to jump start the car or the under the hood remote terminal posts?
    Jun 2016
    Saukville, WI, USA
    Quote Originally Posted by gc325is View Post
    Posts in the trunk.
    Jun 2010
    NY
    1997 328i
    It may be your starter that is bad and it's just a coincidence that it's starting when jumped.
    What is the battery voltage with the car off and when it's running?
    Does the car ever start without it being jumped? (if it does then it's most likely your starter).
    Aug 2009
    sunnyvale CA
    325is
    So the statement is my car does not start with a battery alone, I must add the jump box to it to get it to start.
    As said put a Volt meter on the starter and read it. Sounds like you may have a high resistance drop for a battery alone, loose connector to starter, corrosion on wires bad starter.
  1. Start / Stop parasitic battery drain
    By ccaarmerciill in forum 2006 - 2012 (E90, E91, E92, E93)
    Last Post: 05-25-2018, 09:08 AM
  2. Replies: 29
    Last Post: 10-12-2010, 03:48 AM
  3. Car Won't Start? Check Battery Terminals
    By mjfeeney in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 03-12-2004, 06:33 PM
  4. Custom Battery Tray for OPTIMA Battery
    By RussM3 in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 11-17-2003, 07:06 AM
  5. battery issue
    By MickFly in forum 1991 - 1999 (E36)
    Last Post: 09-30-2003, 06:50 PM
