Results 1 to 5 of 5
Thread: M50B25 - 2.8L ECU solution needed
    Apr 2016
    gilbert, az
    1995 BMW 325i sedan
    M50B25TU - 2.8L ECU solution needed
    I've found myself in a situation where I have a M50B25TU (single vanos) with the crank, rod, and pistons out of a M52B28 and (stock cams, intake, exhaust) and I don't know what ECU solution i need in order to run it. I've read various claims of running a different ECU's but I wanted some feed back from people who may have done this same thing and what they've done to get their cars running.
    This is an OBD1 and the original ECU is the BOSCH silver 413.
    Oct 2003
    Seattle
    99 M3
    Jim C used to have a huge list of Red Label “413” ECU chips. Check out the Turner Website, I imagine the have a chip for your set-up.
    Apr 2016
    gilbert, az
    1995 BMW 325i sedan
    Thanks for your response.
    I spoke with Turner and they said they didn't have anything for me.
    Your comment about the Red Label 413 implies that it would run the setup. Could you clarify what you were saying with your reference to the Red label 413?
    I'm really just looking to get the engine running properly. I'm not overly concerned with trying to get a nice performance tune out of it yet. Step 1, get car running.
    Dec 2009
    Detroit
    E36 Compact,Coupe,E30
    I had a 2.8 M50. Ran silver label 413 with chip made from Racing Pros on ebay. Very nice guy and would be able to tune finer if you can hook up a wideband. Currently using his tune on my full OBD1 s52. Never had any issues. Turner should be able to help. There are plenty of tuners that should be able to do this.
    S52 E36 Compact
    E36 325is Coronaproject
    08 Saab 9-3 in Oxford Green
    Vancouver, BC Ca
    1993 325is
    Zack from 22rpd.com can make you a custom tune/chip for the red label 413 that'll make that motor sign. I've worked with Zack on my custom OBD1 stuff and he did a great job. Get in touch with him for an OBD1 tune. He's also on here as "vollosso".
  1. auto solution ssk???? better than UUC?
    By MMNJTWA in forum 1992 - 1999 M3 (E36)
    Last Post: 01-11-2004, 01:49 AM
  2. Solution to 92 325's slugishness at 2-3k rpm
    By BlackBimmer in forum 1991 - 1999 (E36)
    Last Post: 08-21-2002, 09:14 PM
  3. a/c lights out? solution....
    By BMJaz in forum 1991 - 1999 (E36)
    Last Post: 03-08-2002, 11:54 PM
