Results 1 to 17 of 17
Thread: Z3 ABS Pump
    Apr 2008
    Long Island ,NY
    95 M3 , 99 Z3 Coupe sold
    Z3 ABS Pump
    Ok I have a 98 Z3 ABS pump failure of the two front solenoids, my question is this,
    I also have an 95 e36 coupe parts car ,is the ABS pump the same in my E36 if so can I install it on my Z3??
    Thank you
    I'm an Aussie living in the States , love it
    Modestly dyslexic so for give the spelling.
    Jul 2005
    Temecula Ca.
    99 M Coupe LS Swap
    Look up part numbers and what car the part is on at realoem.com
    Dan "PbFut" Rose
    Jul 2004
    Houston, TX
    36 Cylinders
    Likely not compatible. But what exact models are we talking about? Last 7 of VINs? ASC present?
    Some of the early pump solenoids had their internal power supply ribbon crack with age, and it's fairly easy to rewire inside for an easy and cheap repair.
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
    Aug 2012
    Kansas
    2000 m roadster 2010 x3
    It might also be nothing to do with the pump but rather a broken solder pad on the abs module. My 99 2.3 showed abs pump fail when it cracked.
    Apr 2008
    Long Island ,NY
    anyone have the pump and module assembly part number
    Feb 2012
    UK
    1998 Z3 1.9 5 speed
    Go to realoem.com and enter your vin to find the parts that are specific to your car.
    Aug 2012
    Kansas
    ABS pump failures are extremely rare in my experience. The Z is the only car that ever showed this fault and as stated before was actually the module. Check out Module master website.
    Jan 2016
    Kyoto
    E92 M3, E36 M3 evo, Z3
    If ABS and ASC are on, it's most likely the rusty wheel speed sensor (rear) that needs some abrasive. If it failed, I would just take out ABS all together since BMW ones are way too aggressive anyways.
    Mar 2004
    Blue Ridge Mountains, NC
    1999 Z3 Coupe
    If your ABS/ASC lights are on and you've nothing better to do. You may want to peruse this thread. The pump diagnosis is usually bogus as others have already said, but especially on 99 coupes.
    https://www.bimmerforums.com/forum/s...On-DIY-sort-of
    1999 2.8 Z3 Coupe
    Arctic Silver
    Jul 2004
    Houston, TX
    36 Cylinders
    98 z3 has a totally different abs system from 99-2000 Z3. The fixes mentioned above will not apply.
    -Abel
    Apr 2008
    Long Island ,NY
    Thanks ...we plugged in in at the dealer my fried works there and it showed that the two fron abs solenoids were failed closed so when the brakes are applied the calipers won’t release all they way dragging the brakes till they eventually lock up
    i don’t think you can replace them it looks like a complete module that’s $1400 from BMW the component sits under the brake master and has the pump on it and the solenoid module attached to it looks like one complete unit
    Jul 2004
    Houston, TX
    36 Cylinders
    This is likely what is going on.
    http://raysaywhat.blogspot.com/2014/...8-bmw-e36.html
    I had this on my 328 before.
    -Abel
    NY
    skateboard
    I had the same issue with one of my 95 m3’s years back, and re-soldering the wires was the fix.
    ― George Orwell
    Mar 2004
    1999 Z3 Coupe
    Oops, my bad. His car list shows a 99 Z3 coupe. Sorry, should have read his post more carefully.
    1999 2.8 Z3 Coupe
    Arctic Silver
    Apr 2008
    Long Island ,NY
    Quote Originally Posted by daven View Post
    No I have both a 99 Z coupe and a 98 Z3 roadster this issue is on the roadster
    Apr 2008
    Long Island ,NY
    Dec 2007
    Great Dismal Swamp
    E36/7 E36/8x2 E46 F25
    I think this one needs to be properly diagnosed before you plunk down a lot of time and money.
    /.randy
  1. WTB New pump
    By Balthazarr in forum BMW Parts Wanted
    Last Post: 09-22-2003, 11:47 PM
  2. Oil Pump nut a DIY?
    By Tanks95 in forum 1992 - 1999 M3 (E36)
    Last Post: 07-11-2003, 08:55 PM
  3. Need help to replace water pump, tstat and housing, power steering pump
    By dvs //m3 in forum New York / New Jersey / Connecticut
    Last Post: 05-17-2003, 11:12 AM
  4. Oil Pump Nut?
    By moonluv810 in forum 1992 - 1999 M3 (E36)
    Last Post: 12-27-2002, 12:15 PM
