RM European Auto Parts
Results 1 to 9 of 9
Thread: M52TU/M54- Oil Filter Housing is stuck to the block
    CA
    '82 Euro 635CSi
    Hi there. I have an M52TU 528i, same oil filter housing as the M54. I am trying to remove the oil filter housing in order to replace the gasket inside that I suspect is leaking. However, upon trying to pull out the housing itself after removing all the bolts (including the VANOS line), the thing won't budge- it's like it was welded to the block.
    I have tried PB blaster and a pry bar, but this thing is completely stuck. Any advice? Do I just keep applying PB and waiting till it does its job?
    -To clarify, I am not talking about the 36MM nut on top of the housing, I'm referring to removing the entire housing from the engine block.
    https://www.youtube.com/watch?v=AyEBq3A7On4
    Current
    - '82 Euro 635CSi, '01 MBZ SL500
    Past- '08 328Xi Touring, '00 528i Touring, '86 635CSi, '81 Euro 635CSi, '72 2002, '93 325i S50 swapped M3 clone
    MauiM3Mania's Avatar
    Jan 2002
    Central Pacific
    88M3 99M3 04M3 ITBx16
    How many bolts have you removed from the housing?
    88M3 AW 43k miles Project FS
    NW suburban Chicago
    hiss by my window
    Quote Originally Posted by MauiM3Mania View Post
    My thoughts too.
    OP, have a look, at your new gasket which ought to indicate all the bolt locations. Me thinks you've missed one and ought not be using that pry bar. If this is too late I have a spare housing FS
    Dec 2013
    Chicagoland area
    EXOTICS
    Have you watched any YOUTUBE vids to help you out?
    I replace the oil filter housing on a m54 last summer,
    vids helped out!
    Jun 2002
    Aberdeen, NC (yes, again)
    E39M5, E500 4WD
    There are 6 black bolts, different lengths, holding the housing to the block.. Plus, you need to unbolt the power steering pump (3 bolts, 2 are long, one is short, and comes upwards at the back of the pump, through a bracket.)Do you have all these bolts on your workbench?
    Chris Powell
    BMWCCA 274412
    Dec 2013
    Chicagoland area
    EXOTICS
    Exactly Chris,
    but I suspect OP has not removed the alternator or PS bolt.
    A prybar should definitely not be needed,
    as the aluminum face of the housing and engine block do not exhibit that corrosive effect.
    CA
    '82 Euro 635CSi
    Update: I am a complete idiot. Forgot to remove two sneaky bolts (bottom and top right). Wasted about an hour being completely stumped until I looked at the new housing and realized that only four of the six bolts were there.
    Sorry to waste everyone's time.
    Current
    Jul 2004
    Houston, TX
    36 Cylinders
    Ehhh, complete idiots do not learn from their mistakes, and do not listen to advice.
    So you're all good.
    Glad you've solved it without damage.
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
    Jun 2002
    E39M5, E500 4WD
    +1.
    You sought out an answer, you looked for, and found the issue. I promise, I've made far more, and far worse mistakes.....
    Chris Powell
    BMWCCA 274412
  1. S54 oil filter housing
    By C.Thurman in forum Engines, Performance Parts & Software
    Last Post: 03-31-2014, 04:25 AM
  2. Oil Filter Housing / Canister
    By Bimmer Pilot in forum 1991 - 1999 (E36)
    Last Post: 03-26-2004, 10:18 PM
  3. VAC Oil filter housing
    By badmonkey in forum 1992 - 1999 M3 (E36)
    Last Post: 04-20-2003, 01:01 PM
  4. Ice Block Stuck In Rim Or Something Else?
    By Dan in forum 1991 - 1999 (E36)
    Last Post: 03-09-2003, 09:06 PM
  5. Oil filter housing
    By bungy42 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 07-12-2002, 08:15 AM
