Results 1 to 6 of 6
Thread: Water in Foot Well: 325i Convertible
    Jul 2006
    Southern California
    1989 325i Conv.
    I did a search, but the culprit in most seemed to be the sunroof. I have an 89 325 Convertible (so no sunroof) . When I washed it, the carpet under the floor mat was a bit wet. I don't really spray the top when I wash it, so I don't think it's a leak from the top. Is there a drain or something somewhere that could be blocked that I should clean out or something?
    Thanks in advance for any thoughts.
    Dec 2005
    corpus christi, texas
    No e30s, again :(
    not sure on e30 soft tops but on other vehicle soft tops, the leak is always where the wind shield makes that turn downwards. the rubber piece of the soft top gets old and starts leaking there so it follows the door frame down and comes out under the carpet
    the other spot I have read about, I think, is in the vents by the wipers. if I remember right, there is a drain that plugs, or maybe its rust that forms in there
    No e30s again.
    Jul 2006
    Southern California
    1989 325i Conv.
    Thanks!!
    I'll check the vents by the wipers (because I didn't get the top wet). Does anyone know how to check, and unclog, them? Should I remove the covers and try to stick pipe cleaner down there?
    Dec 2005
    No e30s, again :(
    Look first to make sure but if there is clogged drain, it should come out somehwere you can stick a wire in it or put a shop vac on it
    No e30s again.
    richardodn's Avatar
    richardodn is offline Old Guy BMW CCA Member
    Moderator
    Nov 2008
    Lakewood, CO
    20 440ix cab, 12 X3 35ix
    It's almost certainly the "elephant trunk" drain on the firewall is clogged. google "e30 elephant trunk"
    "Howdy, Folks!"
    Aug 2011
    Wake Forest
    2004 525i, 1985 325E
    Remove the drivers side windshield wiper. Then remove both cowl vent covers. Clean any debris you find. Both those wells drain out behind the fenders. Make sure they are clean. Pour in some water and make sure it drains out to the floor. The drain holes in the rocker panels can clog too causing rust but probably not your problem. Also, as mentioned before, on the passenger side, by the battery tray, you'll find a black tube about an inch or so wide and maybe a half inch thick, this is AKA the elephant tube or drain. Make sure that is clear.
    One other that had me stumped was under the hood gasket, passenger side, there is a gap between the fender and the cowl itself. Water was dripping onto the AC hoses and through that firewall gasket. The hint was water on the battery tray.
    Almost forgot, under the HVAC box, there are three drain tubes. They tend to crack with age, but those leaks tend to be under the carpet.
    2004 525i Sport, Manual - 1985 325E Coupe Manual
  1. 95 325i convertible
    By GreenD in forum BMW Cars For Sale / Wanted
    Last Post: 05-17-2018, 12:09 AM
  2. 1991 E30 325i Convertible
    By poofacekiller in forum 1983 - 1991 (E30)
    Last Post: 02-13-2004, 05:31 PM
  3. Need 325i Convertible Help
    By JoeCinVA in forum 1991 - 1999 (E36)
    Last Post: 12-20-2003, 11:52 PM
  4. Water on my foot!
    By document in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 05-23-2003, 05:57 PM
  5. Feeler: 95 BMW 325i Convertible 50k
    By Badass Bimmer in forum BMW Cars For Sale / Wanted
    Last Post: 02-25-2003, 04:20 PM
