Results 1 to 3 of 3
Thread: E30 lock issues
    May 2018
    Illinois
    92 BMW 325i convertible
    E30 lock issues
    Drivers side lock.
    I have taken the lock apart and lubed with on PB blaster. It works good. The actuators on the car do not lock or unlock doors but I hear a click on the dash when I unlock the door.
    The drivers side door can not be locked manually when the door is open, only when it is closed. The drivers side door lock will unlock the door sometimes, but with some resistance.
    When I have the nut and bolt out of the door panel with the white tab out of the slot the lock goes up and down easier by hand.
    Passenger door can be locked with door open or closed manually. Unlocking door also has some resistance. Door has not been lubricated.
    Are my actuators causing my difficulties?
    dworthy's Avatar
    Nov 2010
    Grafenwoehr, Germany
    16 220i 05 325it 05 M3
    Welcome to the Forum!
    PB Blaster is only for loosening up stuff, it is not a lubricant. For door locks, you need grease, preferable white grease as it hangs around a lot longer. Now you cannot lock a BMW driver's door with it open, it's to keep people from "accidently" locking the keys in the car. Just like if the drivers door is open, and you lock the trunk, the central locking will lock, then unlock right away.
    Yes check to see if all the parts are moving freely, as you have 3 masters: Driver's, Passengers, and trunk. If one isn't working properly, then it can throw the system out of whack.
    Darin
    Current:
    Past:
    79 525 euro Green/Green RIP
    M-Flight Member
    May 2018
    Illinois
    Everytime I lock can passenger door or trunk I hear a click on the dash. When I lock drivers door manually with my hand I hear a click on the dash. All locks can be unlocked with a key but do not unlock any other doors or trunks.
    There is no physical activity from central locking system outside of the clicking.
    Also, there is a cable in the trunk that follow the curvature of the left trunk hinge. What does that connect to?
    I do not have a 1992 BMW 325i convertible owner’s manual to review any of this.
  1. Added a remote to lock system now it wont lock or unlock Helllllllp
    By russ1150 in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 11-01-2003, 08:59 AM
  2. Faster lock to lock steering?
    By Fissionx in forum 1992 - 1999 M3 (E36)
    Last Post: 06-02-2003, 02:16 PM
  3. Lost my wheel lock key.need size socket to remove lock
    By BzAlwayzLit in forum 1991 - 1999 (E36)
    Last Post: 02-08-2003, 05:37 PM
  4. Euro 3-spoke St. Wheel switch/lock support issues w/ dealer.
    By Drea///M3 in forum 1992 - 1999 M3 (E36)
    Last Post: 01-31-2003, 04:53 PM
