Results 1 to 6 of 6
    Jul 2011
    Euless, TX
    2001 X5 4.4
    Challenge accepted and now I'm kind of stuck! Need help with failsafe mode
    Picked up a 2001 BMW X5 4.4 DEAD off an auction. I love to fall in a big BMW troubles and I find the pleasure digging myself out!
    Abandoned bimmer with no key. I never made a key before, but last time I called an independent locksmith to make a key for E39 I was charged $300 for 15 minutes job and the key didn't even look like it belongs to a German car. I researched, bought the tools and materials and thought myself how to make the key from scratch. <<< (Pleasure)
    Car started very rough with many codes on the cluster and regular obd scanner. Next day I plugged my booster to the battery and it wouldn't start. Researched and it was EWS needed a reset. Got the KDCAN cable online, installed the INPA software and after two days got it to run again. Very rough idling with P1635 code, Cleaned the Throttle body, reset the adaptation but with no luck.
    With the rubber hose out I cleared the codes and I could see the flap ticking, I read that it should take a full open close position after reset or after you turn the ignition to position 2 before starting the engine. I purchased another Throttle body and it did the same exact thing.
    Battery voltage is 12.5v off and 14.01v after. Tried to register the battery (non BMW) but couldn't find the option in INPA, tried EDIABAS but got lost!
    Checked the Thermostat plug and it was fine, checked the DME connectors and all were clean.
    Now cluster shows Engine failsafe / Transmission failsafe / coolant low (actually it's full)
    Status: Idles rough/ gas pedal no response
    Now my INPA report displays in German, I checked the INPA.INI and it looks good. copied the EDIABAS\ECU folder back from the backup but still German. The report shows the following errors:
    E R R O R M E M O R Y R E P O R T
    Date: 05/20/18 18:11:34
    ECU: ME72KWP0
    JobStatus: OKAY
    Variant: ME72KWP0
    RESULT: 6 errors in error memory !
    130 DK Positionsueberwachung
    Error frequency : 1
    Logistic counter: 40
    Versorgungsspannung 22.04 V
    Ansauglufttemperatur 30.75 Grd C
    Winkel DK bez. auf DK-Anschl. 3.53 % DK
    Sollwert DK bez. auf unteren Anschl. 19.14 %
    Fehler geprueft
    Abweichung zw. DK Ist- und Sollposition zu gross aktuell,
    Abweichung zw. DK Ist- und Sollposition zu gross Initial,
    33 Nockenwellensteuerung
    Error frequency : 1
    Motordrehzahl 1000.00 /min
    Motortemperatur 77.25 Grd C
    wnwi1_u -1.00 Grad KW
    tanwrhf_0_A 46.28 % TV
    Fehler momentan vorhanden
    nicht korrekte Anzahl von NW-Flanken aktuell,
    nicht korrekte Anzahl von NW-Flanken Initial,
    SCATT-aktiv
    98 Tankentlueftungsventil Endstufe
    Error frequency : 16
    Error occured 1. times at:
    Motordrehzahl 1280.00 /min
    Motortemperatur 78.00 Grd C
    Versorgungsspannung 12.43 V
    Fahrzeuggeschwindigkeit 0.00 km/h
    Error occured 2. times at:
    Motordrehzahl 1200.00 /min
    Motortemperatur 79.50 Grd C
    Versorgungsspannung 12.53 V
    Error occured 3. times at:
    Motordrehzahl 920.00 /min
    Motortemperatur 86.25 Grd C
    Versorgungsspannung 12.34 V
    Signal-/Pfadunterbrechung aktuell,
    Signal-/Pfadunterbrechung Initial,
    Fehler sporadisch
    140 Endstufe Thermostat Kennfeldkuehlung
    Error frequency : 20
    Fehler sporadisch
    134 Pruefung unterer Anschlag
    Error frequency : 5
    Versorgungsspannung 10.64 V
    Ansauglufttemperatur 37.50 Grd C
    Spannung DK-Poti 1 0.84 V
    udkp1a_u 0.04 V
    Versorgungsspannung 10.08 V
    udkp1a_u 0.04 V
    Ansauglufttemperatur 39.75 Grd C
    udkp1a_u 0.04 V
    Fehler geprueft
    Pruefung unterer Anschlag fehlerhaft aktuell,
    Pruefung unterer Anschlag fehlerhaft Initial,
    E-Flag entprellt
    CARB-entprellt
    SCATT-aktiv
    MIL ein
    Fehler sporadisch
    136 Pruefung Notluftpunkt
    Error frequency : 1
    Versorgungsspannung 10.17 V
    wdknlp 16.86 %
    Sollwert DK-Winkel in NLP-Stellung 16.86 % DK
    Fehler geprueft
    Pruefung Notluftpunkt fehlerhaft aktuell,
    Pruefung Notluftpunkt fehlerhaft Initial,
    SCATT-aktiv
    Any piece of info regarding any issue of the above will be highly appreciated.
    Jul 2011
    Euless, TX
    2001 X5 4.4
    Jul 2011
    Euless, TX
    2001 X5 4.4
    Jan 2016
    Montreal/Cape Coral
    2012 X6 35i
    Ever get it figured out?
    2007 FJ Cruiser (best vehicle to date)
    2012 X6 35i Sport
    2013 ML350 BT
    2019 4Runner
    Jul 2011
    Euless, TX
    2001 X5 4.4
    What is your issues exactly?
    Jan 2016
    Montreal/Cape Coral
    2012 X6 35i
    I don't have any, was just wondering if you ever got it all figured out.
    2012 X6 35i Sport
    2013 ML350 BT
    2019 4Runner
  1. Transmission Failsafe prog????
    By Panchal86 in forum 1995 - 2001 (E38)
    Last Post: 11-28-2019, 04:50 PM
  2. Just accepted a new job - good or bad?
    By NewM3er in forum Off-Topic
    Last Post: 09-12-2003, 09:45 AM
  3. Whats up with Sport Mode and Manual Mode
    By Ryan328i in forum 1991 - 1999 (E36)
    Last Post: 12-04-2002, 06:03 PM
