Results 1 to 8 of 8
Thread: M70 Clutch Options - e32 Manual Swap
    SLC, UT
    2001 BMW M5
    Hello e31 friends! I'm converting my '89 750iL to a manual trans and am looking for 850ci or csi clutch kit options. I've amassed all of the other necessary bits, and thought this would be the easy part, but thus far I've come up nearly empty :'( Looks like the OEM parts are NLA as of 2010, and many of the aftermarket options have been discontinued.
    I'm using an oem 850 manual single mass flywheel and a Getrag 420g with and adapter ring (will accommodate the 280mm clutch no problem). This particular 420g (from an e34 540i) has a 1-3/8", 10 spline input shaft just like the 560g used in the e31, so any stock 850 (ci or csi) clutch, bearing, and pressure plate should work.
    I purchased an Exedy kit that claimed 850csi fitment on eBay, and it's all wrong (huge surprise, right?), so I'm hoping someone might be able to tell me what they've had success with before I just guess again. I know manual e31s are somewhat rare, but surely someone here has replaced a clutch in the last five years? Here are the options I've found to date that I *think* will work:
    • Spec SB271
    • Exedy KBM10
      • NLA from Exedy. Few sellers on eBay charging big money. Specs look right, but is there a better option?
      • I now know from personal experience that the KBM11 some sellers list for the 850 _does not_ fit
      • $1,300 for the kit
    • Centerforce II MST559033
      • Another one that someone has listed for the 850 that I can find nothing to substantiate fitment. The disc, at least, looks like it would work. The overall diameter and input shaft dimensions are right. No idea about the pressure plate though. The manufacturer's documentation only lists Ford applications.
      • https://www.summitracing.com/parts/c...9033/overview/
      • $270 + an oem throwout, which seems too good to be true!
    • UUC Moter Werks
    • BMW OEM NOS parts I've crossed numbers and found online. In stock? Who knows. Seems risky...
      • 21211223408 - Reman pressure plate - $200
      • 21211223410 - Reman clutch disk - $240
    Any luck with any of the above? Other ideas? If this has been discussed elsewhere, I apologize. I've searched this (and several other) and found a lot of folks discussing this swap, but precious few details about anyone completing it and no good clutch info. I should probably take that as a sign, but what fun would that be? Thanks!
    Nov 2009
    Las Vegas, NV
    95 840ci 6sp,00 750iLV12
    I'm in the process of replacing my clutch. I purchased the UUC kit with the 850csi conversion kit. I will keep you posted on how it goes. Should be completed by June 4th. I'm dropping car off to Indy before I go out of town for 2 weeks. Clutch kit is for my e31, therefore I spared no expense.
    Sent from my SPH-L720 using Tapatalk
    Sep 2008
    Santa Barbara
    91 Dinan860 & 91 850 6sp
    '91 Dinan 850 TT stage III (brand new engine)
    '91 850i 6sp (mint)
    '90 Dinan 750iL TT stage III
    '94 850 CSi (being restored to factory perfect)
    '94 840ci (4 short - obvious parts car), '91 850i parts car
    '73 3.0 csi, '08 535i, '95 318i
    SLC, UT
    2001 BMW M5
    Quote Originally Posted by cartoonz View Post
    Thanks for the suggestions! As I understand it, the SB011 referenced there is the 850CSI version of the SB271 I mentioned as my likely best option. The SB011 seems to run ~$50 cheaper everywhere, but since I have an M70, not an S70, I figure the SB271 is the better bet (although the SMF p/n is the same, so I suspect either would work).
    Since posting, I did identify an updated p/n for the remanufactured BMW kit: 21210444900. Best price I've found is $940, but it appears to include the throw-out, so that certainly makes it competitive with the SPEC option. Probably what I'll end up purchasing.
    Mar 2016
    Tyler, TX
    1992 E31 850i
    If you plan to do anything greater than stock power, look for an aftermarket / non-OEM solution that can handle it. I have the CSi setup on a twin-turbo M70 car, and I have to baby that clutch. At stock power levels I'm sure it is fine, but I wish I had gone with something a little more heavy-duty at the time of the build. I certainly will if I ever run enough miles to need a replacement.
    Cheers, John
    Sep 2008
    Santa Barbara
    Quote Originally Posted by sutekh View Post
    The CSi kit is compatible with M70 too... same thing really. But lots of places don't actually recognize there were 6sp M70 cars and don't list anything, but do for the CSi's as they were all manual trans cars.
    The link I posted for the Spec kit was markedly lower than from Spec itself...
    '91 850i 6sp (mint)
    SLC, UT
    2001 BMW M5
    Thanks for confirming what I suspected. I was ballparking the pricing based on MSRP, but this is the SB271 I have my eye on for $745: https://www.amazon.com/Spec-Tools-SB.../dp/B06XYTKDSH
    Thanks for the power reminder, John. The 750 is currently parked next to my M30 powered e34 that I turbocharged several years ago, so forced aspiration is definitely a possibility I'd hate to paint myself into a corner! I've definitely toyed with the notion of supercharging the M70 (which seems the most civilized option for that buttery smooth motor).
    Feb 2013
    Kalamazoo, MI
    E34 540i6, E46 323i, E36
    sutekh,
    What clutch setup did you end up going with? Have you converted the 750il yet? I'm dreaming of converting my E32 750il to a 6 speed as well. Do you know if the 420g from the early E39 540i's has the same input spline as the 560g? I noticed you are using a 420g from an E34 540i, but I have always heard that the early E39 and E34 420g's are the same?
    Also, with an adapter ring don't you need something to space the flywheel back from the crank? Thanks
  1. 1995 e36 318i swap options... Need help/advice
    By 318rob in forum Engine Conversions
    Last Post: 05-14-2018, 11:30 PM
  2. 318 tranny swap options
    By onrails318 in forum 1991 - 1999 (E36)
    Last Post: 04-23-2004, 02:19 AM
  3. Clutch Options?
    By G.T. in forum 1992 - 1999 M3 (E36)
    Last Post: 01-04-2004, 04:39 PM
  4. clutch options?
    By Emmasis in forum 1992 - 1999 M3 (E36)
    Last Post: 06-21-2003, 06:17 PM
  5. engine swap, and other options for more displacement
    By gbeale in forum 1991 - 1999 (E36)
    Last Post: 06-04-2002, 06:40 PM
