Results 1 to 5 of 5
Thread: Troubles with B-Cables and K+Dcan and windows 10
    Osnabrock, ND
    2004 325xi,2004 545i SMG
    Hello my son and I purchased the Bcables K+Dcan setup for our e60 and e46 cars. We installed the software on my laptop (64 bit windows 10) and everything went ok.
    followed the directions supplied and connected to vehicle and nothing. cannot identify vehicle, and if I manual identify the vehicle it only lets me see the DME.
    Progman/SSS doesn not load correctly and also will not connect to the vehicle.
    didn't try the others but I am assuming the windows 10 is the problem.
    anyone get this to work? anyone care to guide me through this with out making it sound like I am a dumb ass.. (which I probably am)
    thanks
    Level 1 Certified BMW tech.
    Jul 2004
    Houston, TX
    36 Cylinders
    I would verify that your COM port settings match first.
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
    Osnabrock, ND
    yup did that, followed all the you tube and online help I could get. dont know what the problem is.
    Dec 2013
    Spain
    Mini Cooper
    Same problem here with E53 4.4 only dme and egs show up. have a trouble with the air suspension.. ( see picture ) Running on Windows 7
    Dec 2013
    Spain
    Mini Cooper
    I think i found the solution, there is also a 20 pin connector under the hood, in 2 days i have my 20 pin to obd cable, and can find out if it will work
  1. DCAN cable connection issues trying to register new battery
    By jeff91121 in forum 2006 - 2012 (E90, E91, E92, E93)
    Last Post: 05-13-2018, 02:31 PM
  2. car troubles
    By nateb in forum 1983 - 1991 (E30)
    Last Post: 12-18-2003, 11:16 PM
  3. Car troubles
    By M-Theory in forum 1991 - 1999 (E36)
    Last Post: 09-03-2003, 09:50 PM
  4. Which of 2 is the best way to run RCA cables
    By 2pak in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 07-28-2003, 08:40 AM
