Results 1 to 9 of 9
Thread: New/Used or Reman for steering parts
    Dec 2009
    Detroit
    E36 Compact,Coupe,E30
    Hi all - I would like to replace the steering components but not sure of the current quality of the manufacturers we have choices from. Currently looking for an e36 rack, m50 pump. I have new upper shaft and the lower u joint is now solid metal from e34.
    From looking around it appears the new racks are built by Atlantic Automotive Enterprise/ AAE. Reviews of their product line don’t seem too bad and I know they recently were purchased by CRP Industries which oversees Ajusa, Pentosin, Rein which I’ve all had good parts with. Reman racks are Bosch/ZF or A1 Cardone. I’d imagine the most secure option would be the rebuilt ZF rack. I will also look for a local shop to rebuild a core.
    Looks like for M50 style pumps Luk is no longer making any and only new option is whatever BMW has in stock or a AAE reman. eBay does have a few new ones unbranded.
    Anyone have any suggestions? I realize best bang for buck would be to snag used OE ones but if the AAE aren’t too bad I would like new. Thanks for any help!
    Sent from my iPhone using Tapatalk Pro
    S52 E36 Compact
    E36 325is Coronaproject
    08 Saab 9-3 in Oxford Green
    Oct 2003
    Seattle
    99 M3
    Rack Doctor < http://rackdoctor.net > has a pretty good reputation for a ‘rebuild’ and they are one of the least expensive.
    It looks like there are pump rebuild kits for the LUK/Vickors pump -
    http://www.realoem.com/bmw/enUS/show...diagId=32_0889
    Dec 2009
    Detroit
    Thanks, I forgot about RackDoctor. If I end up replacing I will get a stock replacement. People seem to have overall good luck with those. Debating on buying a used pump or an AAE reman now.
    S52 E36 Compact
    Dec 2009
    Detroit
    I got the rack from RackDoctor. Fast shipping and unit seems pretty clean. There wasn’t a core charge as he probably has way to many e36 stock racks around but will send an email just to make sure he doesn’t want old one back.
    Picked up a reman AAE pump from Pelican. Was pretty cheap and with AAE being owned by CRP Industries I have some faith it’s decent. The pump is painted in some gross glossy black enamel paint. I think they do for all products but unnecessary in this situation.
    I’ll post if there are any issues.
    S52 E36 Compact
    Aug 2011
    Vancouver, BC, Canada
    99 M3 Vert
    Glad you got it sorted. For anyone who might be wondering in the future, the rebuild kits are just for the seals, so if you have a leaking pump, that'll get you sorted out, but if you're experiencing rattling issues, a new pump is more in order.
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    The power steering pump kits is consisting of the main shaft seal, some o-rings and 2 profile rings, have already repaired some pumps with such kits, pics of the set https://www.ecstuning.com/b-genuine-...t/32411135880/
    does not include any bearing.
    Dec 2009
    Detroit
    Got the new parts installed. The pump is LUK and not ZF but YMMV. Same bracket/mounting points. A point to note is that the document said to use CH11s for fluid. However when taking plugs out reman pump it was clearly an ATF pump. Time will tell on its longevity. I’ll update with any issues
    S52 E36 Compact
    Oct 2003
    Seattle
    99 M3
    LUK is a factory OE brand pump.
    Dec 2009
    Detroit
    Quote Originally Posted by bluptgm3 View Post
    True, I was more stating that in this case the AAE replacement was a LUK pump instead of the ZF. I am not sure if that will always be the case or if they will reman what they get back. I see the early e36s came with either a ZF or LUK pump. The later ones appear to all be ZF without the threaded housing but the pump itself seemed to be the same as earlier ZF, same mounting holes and pumping pressure by both.
    Also I replaced the E34 solid coupler with a new stock rubber one. Feels much better for street driving, I'll take the preciseness hit.
    S52 E36 Compact
  1. MKIII: cheapest place to buy reman...>
    By DavidF in forum 1995 - 2001 (E38)
    Last Post: 02-02-2004, 03:42 PM
  2. Reman Superchargers?
    By DK325IS in forum Forced Induction
    Last Post: 08-04-2003, 03:23 PM
  3. Burning oil at end of and after breakin period (reman engine)
    By MrChaos in forum 1992 - 1999 M3 (E36)
    Last Post: 07-19-2003, 12:39 PM
  4. Reman 318iS Parts
    By dobleuno11 in forum BMW Parts For Sale
    Last Post: 01-27-2003, 02:40 PM
  5. FS: Reman ECM for 82-85 5, 6, or 735
    By South_Paw757 in forum BMW Parts For Sale
    Last Post: 10-05-2002, 08:15 AM
