Results 1 to 10 of 10
Thread: A/C fan inop after dead battery
    Jul 2010
    KC, Mo
    04 M3, 02 E39, 01 46 M3T
    After my S54 E46 Touring transplant, the car has a parasitic draw that is killing the battery. (That is being worked on - long slog !!) The last time this happened, after recharging the battery, everything (I think) is functioning except the A/C fan. Before the conversation goes to the fan resistor, it sounds as if the fan IS SLOOWLY turning on all fan speed selections. In using Google, "Transport Mode" is most often referenced.
    Again, this is a swap car. The host E46 325i is originally a 2001 model with an M54B25, NOT M52TU. The S54 is a 2002 S54 with its DME. That said, I am assuming this issue is about a body module, not the engine module.
    Thoughts?
    Dec 2013
    Chicagoland area
    EXOTICS
    Have you replaced the Blower Motor Resistor?
    Common cause of parasitic drain.
    Jul 2010
    KC, Mo
    Quote Originally Posted by MIKYZZ4 View Post
    No, I haven't. But, my greater concern is that the A/C fan is not operating. The fan symptoms are NOT that of a bad resistor.
    Jul 2010
    KC, Mo
    Well --- surprise surprise ............... fuse 40 (visually) checked good. I put it back in and POOF !!!!!!!!!! The fan works.
    Mar 2015
    west chicago il
    01 E46 330i 5sp man spor
    I would start shopping for a final stage unit. They fail in all sorts of ways. Some have the fan running with the key off, some have no fan at all, some cause erratic blower motor function and some cause the blower to run on high no matter what the panel is set on. It's not difficult or expensive.
    Sent from my SAMSUNG-SM-G870A using Tapatalk
    Jul 2010
    KC, Mo
    Quote Originally Posted by randy72877 View Post
    Understood, but a bad connection at a fuse was the issue. Not the first time I have seen something like that.
    Mar 2015
    west chicago il
    Was it the 50A maxi fuse behind the glove box?
    Quote Originally Posted by snaponbob View Post
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    No, the 50 amp fuse is in the fuse panel.
    Jul 2010
    KC, Mo
    It was not the 50 amp fuse. There is a smaller, 30 amp fuse that was the culprit. I think it was F20.
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    According to my fuse chart fuse slot 20 is empty.
  1. battery dead
    By kpytoi9 in forum 1988 - 1996 (E34)
    Last Post: 01-27-2004, 10:19 PM
  2. dead battery
    By kosta in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 01-26-2004, 06:36 PM
  3. I Think My Battery is Dead!!!!
    By EVAN1076 in forum 1996 - 2003 (E39)
    Last Post: 12-10-2003, 04:02 PM
  4. Battery is dead
    By Preppy in forum 1991 - 1999 (E36)
    Last Post: 01-03-2002, 12:44 PM
  5. dead battery ?
    By rockstar in forum 1992 - 1999 M3 (E36)
    Last Post: 08-01-2001, 05:01 PM
