For over-the-counter coatings, I believe layering can be beneficial for a private DIY'er owner. But one must exercise caution that they are not attempting to "layer" by reapplying too quickly after a previous layer application. Coatings have transfer solvents(in most cases, I believe these are alcohol-based solvents).
The reason OTC coatings may benefit from layering moreso than some other professional coatings, is that the thing that makes them user-friendly as an OTC coating is the same thing that limits the active ingredients(si02). The transfer-rich solvent mixture in OTC coatings will easily break down an previous coating layer if applied before cured to a healthy measure. To what specific healthy measure? That would be different from coating to coating but my advice is to not even consider layering over a coating within 24-48 hours. IR lamp treatment will not change this very much, if at all, based upon how IR lamp treatments actually work(which is different from what many people believe).
Long story short:
OTC coating and you want something a bit more than basic? Sure, layer. But wait 24-48 hours before reapplying. Too....always be RELIGIOUS about decontaminating before coating and between each corrective preparation step. My advice is to decontaminate every single time you lift your machine/pad from the paint to remove the residue with a mf towel. That will ensure you have the optimal bond of your original layer.
Hope this helps.
“The bitterness of poor quality remains long after the sweetness of low price is forgotten” – Benjamin Franklin
