Results 1 to 12 of 12
Thread: Need help with diagnosing rear end noise - 850 CSi
    Coral Gables, FL USA
    850 CSi/3.0 CSi/E38 740
    Car is making low, groaning noises in 1st gear or reversing; noise disappears when in 2nd gear or above. Is particularly loud when turning at low speed.
    I suspect LSD; recently changed differential oil. Any thoughts on potential cause?
    I am about 1K miles from home, and concerned with making a minor issue into a major one by continuing my drive.
    All help appreciated!
    Ray
    Riding the Depreciation Curve....
    Jun 2012
    Uk
    1994 850csi rhd
    Funny you should mention this, I had my LSD rebuilt with new clutch plates installed recently. I noticed today that when I reverse turning, or pull forward slowly turning, I feel a rumble/groan coming from the rear. I know everything is new back there, so I'm guessing it the LSD kicking in.
    http://www.m3post.com/forums/showthread.php?t=144569
    Does it sound like your tyre is rubbing on the wheel arch? that's what mine sounds like. Apparently this happens after fluid change, you can put an additive in there to get rid of it. Do you know what diff oil you used?
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    My LSD was a groaner on corners - so I added Lubegard LSD additive - and that made absolutely no difference! But using specific LSD fluid did as described here:
    http://www.meeknet.co.uk/e31/BMW_E31...al_Service.htm
    My BMW Repair YouTube Channel
    Thanks for the replies Timm & Omega Man; new +1 tires & new lube- have to check my records on lube type. Will have to wait to get home to further diagnose- and yes, it sounds like tire rub.
    Ray
    Jun 2012
    Uk
    1994 850csi rhd
    I have Syntrax LSD oil in mine. Some people drive their car in a figure 8 pattern in an empty car park for ten minutes ….
    Like this http://www.m3post.com/forums/showthread.php?t=254249
    Oct 2008
    Mt. Dora, Florida
    CSi#18, Tesla S85
    When you change your rear diff fluid....
    ALWAYS make sure you can get the fill plug out FIRST!
    The last thing you want to do is to open the lower drain plug only to find some fool torqued the upper fill plug to 8000 pounds or something crazy. It is not a good day when you open the lower drain plug first, then find out that you cannot get the upper filling plug out to put the new oil in.
    CSi #18 - Car & Driver Magazine 1994 actual test car
    -- Hellrot/Black-Gray (1 of 1 NA CSi color combination)
    BMWCCA E31 Chapter International Clubs Liaison
    North America Representative, 8er.or Board of Directors
    Jun 2013
    Auckland, NZ
    1994 E31 850CSi
    Am assuming from your location that your CSi is a US-spec car - without AHK?
    ECE-spec CSi's (with AHK as standard) emit a low frequency 'drumming' noise when setting off, which is simply the AHK system doing a self-test.
    If your rear tires are concentric and not bulged, I suspect your noise could be either differential-related, or possibly even worn subframe bushings?
    Current:
    1994 E31 850CSi Sterlingsilber/Anthracite Buffalo
    Previous:
    1987 E28 M5 Delphin
    1986 E23 M745iA Arctic Blue
    1986 E24 635CSi Polaris
    1976 E3 3.0 Si Arctic Blue
    Jun 2008
    SF Bay Area
    Supercharged 850ci
    You need to use 85w-140 gear oil WITH LSD friction modifiers. If not you will have a noisy diff.
    If that's not it your bearings are on their way out, not a big deal takes a while for them to completely go.
    If in fact diff needs to be rebuild I can supply the rebuild kit as well as more favorable gear ratio for the rebuild or a separate unit entirely saving you labor cost.
    Good advice, Roger, Thanks.
    Quote Originally Posted by kiwiCSi View Post
    US spec CSi- thought it may be bushings, have to get car on a lift.
    Ray
    Quote Originally Posted by dragon850 View Post
    Good to know, heading back home now to get a better diagnosis.
    Thanks,
    Ray
    Jun 2012
    Uk
    1994 850csi rhd
    I have heard that noise a few times, never seen it explained by BMW though. Thanks.
    Jul 2016
    Chicago, Illinois
    are slow
    These diffs love to leak at the output seals and absolutely will groan without additive, keep that in mind.
    Jun 2013
    Auckland, NZ
    1994 E31 850CSi
    Quote Originally Posted by Omega man 1969 View Post
    No worries, it's a handy tip that not many Euro-CSi owners are aware of - potentially saving hours of troubleshooting an elusive rear-end noise.
    Refer to Section 33-34 of the online E31 Repair Instructions for more AHK info.
    Current:
    Previous:
    1987 E28 M5 Delphin
