Results 1 to 5 of 5
Thread: Gas gauge inaccuracy
    Aug 2015
    Stockton, Calif.
    1999 740Il,1999 Corvette
    My 99 740 IL that I've owned now 2 years has never registered gas remaining accurately. I've changed both senders 3 used fuel pumps and it still runs out of gas at a quarter tank. Today I stopped at the shop replacing my upper/ lower control arms and discovered both tanks severely dented. Appears in the car's past someone tried to raise the car with a floor jack placed under the tanks! Has anyone ever had any success using a 2 by 4 in the tank with floats removed and a hammer to remove the dents? How about compressed air thru the fuel pipes on the float senders? Or... do I resign myself to refueling at a quarter tank or replace both tanks? Every junked 740 has a punctured tank in the wrecking yards here in California. Need opinions on my best option. Thanks!
    Feb 2009
    KC North, MO, USA
    1996 740iL
    I've never seen one personally, but a clogged charcoal canister can cause the tank to collapse like that also. I'd probably live with it myself. I've dealt with a leaky tank and would not do anything that might cause a crack.
    If you have SLS, you have a 95L tank.If you have INPA, you can tell the car you have a 85L tank (non-SLS). That should make the fuel level closer to what the gauge is showing. I had to do this when I went from a 95L to a 85L from a non SLS parts car.
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    My bet is that cluster has come out of a 750i at some point!
    My BMW Repair YouTube Channel
    Feb 2017
    Chicago
    E38 M-Sport & Jaguar XK
    Boy you touched a nerve for me. I have had my 740i sport for a year now and have run out of gas...twice. Yes, twice. The first time was a rookie mistake. The second time the light just came on, the cluster said I had 17 miles to go and I started betting the "Check Engine Soon" light and stumbles within a mile. Painfully embarrassing to have the wife show up with a gas can and a funnel. I just need to remember not to ever get below a 1/4 tank.
    My cluster is from a M5 as I recall (E39?)
    Sep 2014
    Chicago, Il / Denver, Co
    '01 DINAN7 '03 M5
    Just use that said 2x4 and push it down.
    Instagram.com/nordmanmg
    Your current situation is not your final destination
  1. Anyone replaced stock water temp gauge with dual gauge?
    By T&T in forum 1992 - 1999 M3 (E36)
    Last Post: 01-17-2004, 09:32 PM
  2. Gauge Pod?
    By TJFitz in forum 1992 - 1999 M3 (E36)
    Last Post: 11-10-2003, 04:52 PM
  3. New WB AFR Gauge from FJO
    By ///MCubed in forum Forced Induction
    Last Post: 10-06-2003, 07:39 PM
  4. To gauge or not to gauge, that is my question...
    By atlDinan3 in forum 1992 - 1999 M3 (E36)
    Last Post: 09-16-2003, 04:09 PM
  5. E46 m3 gauge in an E36?
    By AaronM3 in forum 1991 - 1999 (E36)
    Last Post: 10-03-2002, 06:20 PM
