Results 1 to 9 of 9
Thread: Advice on maintenance of my 2006 e46 convertable
    May 2018
    Roselle, IL
    2006 BMW M3
    I bought my car last summer- It now has 57000 miles. I have it serviced by a local mechanic who has a really nice shop focusing mainly on older BMW's. I have come to really trust him.
    At 60,000 the manufacturer specs calls for a comprehensive maintenance update- including spark plugs- flushes- etc. I'm sure most of you know about what is included.
    So very soon ill be at that 60,000 mark. I will do what should be done but what strikes me is the car is running perfectly. The engine seems great everything works well.
    A few months ago I asked my mechanic to check the car out before i took a long trip- He said it was in great shape- fixed a few small things-
    Should i just leave it up to him what should be done- Or be more proactive and tell him to do all the things in the 60,000 checklist?
    Thanks in advance for your suggestions-Rick
    MauiM3Mania's Avatar
    Jan 2002
    Central Pacific
    88M3 99M3 04M3 ITBx16
    Hi Rick.... I don't think it would be wise to skip an Inspection. Things go bad on older cars more often than newer cars.
    Is the cooling system original? Thats would be one of systems I'd worry about... and I do, I'm at 65k on my 04 and feel it all needs to be replaced soon.
    88M3 AW 43k miles Project FS
    May 2018
    Roselle, IL
    2006 BMW M3
    Thanks much- I'm not sure if the cooling system is original. But i think my mechanic mentioned something about it. Im going to tell him to do the full 60,000 update. Thx for your advice-Rick
    dworthy's Avatar
    Nov 2010
    Grafenwoehr, Germany
    16 220i 05 325it 05 M3
    +1
    Just because the car is running fine, doesn't always mean you should skip services. I have done more than is needed, and would stick with the schedule prescribed by BMW to keep the car running in tip-top shape. I am about to hit the 100k mark, but I have already done the second Inspection II for the first was done at 51k miles.
    Darin
    Current:
    Past:
    79 525 euro Green/Green RIP
    M-Flight Member
    May 2018
    Roselle, IL
    2006 BMW M3
    Thanks much.... one more question- It will hit 60,000 right around when I put it in storage for the winter- do you think it makes sense to do the maintenance before I put it away or in the spring when i take it out?
    dworthy's Avatar
    Nov 2010
    I always do all the maintenance before storage, as a matter of fact it will be the day I put the car in storage.
    This is pretty much what I do for storage:
    1) Wash and wax the car. Make sure you really clean out the wheel wells, especially around the fender areas.
    2) Clean inside out with a vacuum, then place a drymax bag inside.
    3) Open the all the windows just a little to relieve the pressure off the seals.
    4) Swap out the tires for an old set I have in the garage. If you don't have an extra set, use Flat Stoppers.
    This gives me a chance to really clean the insides of the wheels, and to use rim wax to ensure they stay cleaning the next summer.
    5) Do any maintenance that is needed.
    Normally it is just an oil change, but this last winter I had to do an Inspection II and replaced all the fluids plus oxygen sensors. Those oxygen sensors are in a really bad place and hard to get to.
    6) Put fuel stabilizer in the gas tank, and let the car run for a couple of minutes, also make sure the tank is full.
    7) Remove the battery, and put it in the basement.
    Just as an FYI, my battery is 10 years old and still holds a charge at 12.4V's.
    8) Cover the car to keep the dust off.
    I have been doing this for the past 7 years I have owned the car here in Germany, when I was in Georgia, there was no need to store the car as they don't use salt on the roads anyway.
    Darin
    Current:
    Past:
    M-Flight Member
    May 2018
    Roselle, IL
    2006 BMW M3
    Thank you very helpful- Take care Rick
    Sep 2018
    gig harbor, wa
    2002 M3 6SP
    My son and I purchased a 2002 M3 with 156000 on it this last spring. We have been through the car top to bottom and performed a ton of maintenance items. Take care of them early, as if they go too long, the risks are not worth it. If you are able to do some of the work yourself, it is not that bad, do it. Keeps the costs down and you will really learn the car. Spark plugs, about an hour to complete and once you do it once, you will know how for ever. Just some words of encouragement.
    Jan 2002
    Central Pacific
    +1
  1. E46 2006 325CI Convertible E46 Only 49.5K Miles
    By idfotou in forum 3 series & Z Series
    Last Post: 07-22-2018, 11:43 PM
  2. 2006 E46 Convertible (330ci) for Sale - No Longer Available
    By kbhardwaj in forum BMW Cars For Sale / Wanted
    Last Post: 11-19-2014, 01:57 PM
  3. E46 For sale: 2006 E46 M3 convertible, Washington DC area
    By 3XXM in forum 3 series & Z Series
    Last Post: 11-06-2014, 05:08 PM
  4. E46 2006 E46 M3 Convertible - 34,000 Miles
    By erickropp in forum 3 series & Z Series
    Last Post: 10-30-2010, 04:23 PM
  5. 2006 E46 Convertible HID Kits witn no OBC errors
    By Nick J C in forum Lighting sponsored by BAVToys
    Last Post: 06-04-2008, 06:55 PM
