Results 1 to 8 of 8
Thread: Fuel pump
    Sep 2017
    Ireland
    E36 drift car
    Fuel pump
    Bought a e46 325 with a blown fuel pump,put in a e36 316 pump I had and off it went.problem is it sounds like it’s misfiring at low revs?the icv was blocked but question is is the 316 pump holding it back?thanks in advance
    Nov 2012
    West Point, Virginia
    2002, 320is, 328is, M3
    What control the fuel pump in your car. In the M3 it is the ecu and I was wondering if that might be your problem. Would think low revs would not be the pump unless it is controlled by the ecu. Last time the fuel filter was changed?
    ME:"I want to make my car faster and lighter"
    THEM:" Get out and let someone else drive"
    Sep 2017
    Ireland
    E36 drift car
    Quote Originally Posted by Cobra1956 View Post
    It’s like as if it’s being starved of fuel until you rev it up then misfire goes,just thinking a 316 pump won’t be strong enough
    Nov 2012
    Find the specs on the fuel pump and compare it to what you are replacing. My initial question still stands. Only reason I ask is when I did my engine swap I used the old pump and have never had a fuel issue.
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    The part numbers are the same-they end in 6942.
    Nov 2012
    Could be a bad coil, could be IACV. Go on youtube and look at the videos the 50's kid does on the e46. Simply to follow and takes you through the steps you could use to solve your issue.l Air fuel spark.
    Sep 2017
    Ireland
    E36 drift car
    Cleaned icv and running perfect with 316 pump
    Nov 2012
    That's a good feeling!
  1. fuel pump
    By paul e in forum Forced Induction
    Last Post: 11-09-2003, 10:03 PM
  2. AA fuel pump
    By mrdoenutz in forum Forced Induction
    Last Post: 10-29-2003, 12:06 AM
  3. Can Engine Get Damaged from Fuel Starvation from Fuel Pump Failure?
    By dave162 in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 06-11-2003, 01:15 PM
  4. fuel tank line came off the fuel pump
    By tybmw in forum 1992 - 1999 M3 (E36)
    Last Post: 06-03-2003, 01:43 AM
  5. Fuel Pump
    By jedistlye in forum 1992 - 1999 M3 (E36)
    Last Post: 03-16-2003, 01:54 PM
